The infeed table can’t be adjusted on my jet jj6csx jointer The handle turns but the infeed table doesn’t move. I can see the arm under the table moving. on the threaded screw but the table doesn’t move. Any help is greatly appreciated. The machine is around 10 years old. I’ve never worked on a jointer except to change knives. Thanks for any help.
tom
Manual
If you don't have the parts manual, try this to start http://www.rockler.com/tech/708457K.pdf
You've probably had a set screw back out or possibly even strip. Either way, it shouldn't be too tough to fix.
thanks
Thanks so much the manual is a good place to start, I didn't have one.
tom
