I am building a set of simple bedside table for my daughter. The design is for a single pull out drawer and an open shelf about half way down the legs. I would like to taper the legs on the inside survaces but I am not sure how to attach the shelf to the tapered sides. Any suggestions?
I did a grid-type shelf on tapered legs by hanging a stretcher on 2 sides. You could do something similar and have a solid shelf rest on the stretchers.
If you build it he will come.
A very nice looking table. Maybe the tapered shoulders on the tenons wouldn't be that difficult.
They're actually not all that hard though you do need to change the miter gauge angle from one side of the stretcher to the other. I you dry clamp the table together then clamp the stretchers across the outside surfaces of the legs at the height you need them, you can use a flat marking knife up against the tapered surface. That will get you one side marked for the shoulder. Set a bevel gauge while it's still clamped on. Then use a square and the bevel gauge to get shoulder knife lines on the other 3 sides. Add the tenon length you need and use the bevel gauge to set the TS miter gauge. It don't hurt to put a mark on the stretchers to indicate which side is up. It's usually a pretty small angle on the ends and easy to get turned around the wrong way.If you build it he will come.
You can cut the mortises while the stock's still square, then scribe your mating stock after you've cut the tapers. Floating tenons would make this easier, as you won't have to cut tapered shoulders.
jroger,
The suggestion of stretchers is the strongest and the most trouble, as the shoulders of the tenons must be angled to mate with the taper of the legs.
For a smaller table, up to maybe 28" long x 16" wide, you might consider cutting dadoes across the inside corners of the legs. Make a cradle to hold the legs with the corner of the leg facing the saw's table, or scribe, saw and chop out by hand. The shelf, if 5/8" or so thick will be strong enough for most purposes. Clip the corners off to match the dadoes, and slip into place after assembling the table. Pocket screws on the underside of the shelf hold it in place.
I have an antique tapered leg table that I didn't want to deface by cutting dadoes, so I just notched the 23" x 14 1/2" shelf to fit around the legs, and attached it with just the pocket screws. It holds a DVD player and satellite TV box with no problems now for the last 25 years or so.
Ray Pine
Hey Ray-- Where did you get a dvd player and satellite box 25 years ago?
Jimmy,
Hah, it was a VCR back then, which was heavier than the two boxes that sit on it now.
I thought about cutting notches in the legs but it seems like it would be difficult to notch the four legs to the exact dimensions of the shelf. Maybe it would not really be that difficult.
