I usually use my Routers for almost any joint I make.. Geeee. I’m lazy and it turns out great! Well, the tools work…. NOT mine!
On a whim, I got a new TAKUMA Dozuki ( Ya know as in Japan pull saw )
Fine tooth 190mm.
I have several Japaneese saws (which I use all the time) None with the Back Metal as in the Dozuki.
$45.00 with a replacement blade.. So I hand cut some dovetails with it.. SWEET CUTTING SAW! I may make more…
Now if I can learn pare the wood out as good as the saw cuts…. I may have a NON Electric Router…
Welcome to the dark side Will.
WillGeorge, how anti-American.........you oughta be proud of yourself. All I can tell you for sure about it is watch your fingers. They cut really well.... aloha, mike
They cut really well..Stange you should say that! I did!
<They cut really well..Stange you should say that! I did!>Not strange at all.......its the first thing I cut with a couple of mine and I paid twice what you did. aloha, mike
