I’m working on a hanging rack for quilts. Very simple project. It consists of two boards that clamp together to hold one end of a quilt, and then is hung on a wall. Most quilt racks I’ve seen have threaded shaker like knobs that are used to tighten both boards together. These threaded knobs applied evenly across the boards provide even clamping pressure. Does anyone know how to make these threaded knobs? Are there special tools available for making threaded wood screws? I’m not sure If I’m using the right terminology here, but the only way I can describe the knobs is that they are like Skaker knobs that you would install on cabinet doors, but instead of having a smooth round tenon on the back of them, they are threaded like a woodscrew. Any information on this subject would be very much appreciated.
JF4
Edited 4/13/2009 11:31 pm ET by JF4
You can get taps (for cutting internal threads) and dies (for cutting external threads) that are intended for use with wood. The major woodworking supply places carry them. For example, Lee Valley carries tap and die sets for making 1/2" through 1-1/2" diameter screws and nuts. Warning: They're not cheap.
Thanks saschafer. Can you buy these threaded knobs already made?JF4
I don't recall ever seeing any for sale, but it's not something I've ever specifically looked for, either, so there may be some out there. It seems kind of unlikely, though, because wooden screws/nuts are generally sold as pairs, and for something like what you're talking about building, they'd almost certainly have to be designed to work specifically for that application.-Steve
Steve,Thanks again.Joe
We just had a recent discussion on Making Wooden Threads - I want to make wooden hand screws. The Beall system is expensive and uses a router. I am leaning towards using a tap box (available at Woodcraft among other retailers) which is a fraction of the price and quieter. The downside (minor) is that it won't necessarily cut as clean of thread in gnarly wood. I think that with good, straight-grained stock, I'll be fine with the manual method.
Chris,Thanks for the info. I haven't seen the router method yet. I think I may try the manual method as well.Joe
