I am restoring this rosewood veneer lap desk for my wife. Several of the metal embellishments are missing. I’m pretty sure the metal is aluminum. My problem is how to make the rectangular holes 3/32″ x 13/32″. They need to be nearly perfect for the veneer inserts to fit properly.
If I do it on a jig saw, I’m concerned the edges will not be straight, it will be hard to grip the workpiece, and the edges will be rough.
Any assistance or advice will be greatly apprciated.
If I am understanding your problem correctly, you are trying to insert a piece of veneer into the aluminum. If so, lay the piece of veneer over the aluminum and scribe a line into the aluminum. Then drill out as much as possible without touching the scribed line, insert a file and file to the line.
Hello John,
I don't have an answer for you but, I do have a couple of questions. How old is this lap desk? Is it possible that the metal used is nickle silver, or silver plated brass, or even silver? Might be worth checking into before beginning a restoration.
Bob, Tupper lake, NY
Bob,
I don't think it has any silver because there is no tarnish. In my experience, even with a lacquer coating, silver will tarnish in just a few years. In the period 1850-1880, aluminum was considered to be a precious metal. The low cost electrical smelting had not been invented. The pyramid on top the Washington Monument is aluminum.
John
Hello John,
I knew there was a reason I got up today. I learned something. Now I can go back to bed.
Bob, Tupper Lake, NY
>Now I can go back to bed.<mmbaaaahh ha ha ha ha ROFLMAOrocGive me six hours to chop down a tree and I will spend the first four sharpening the axe. Abraham Lincoln ( 54° shaves )
Edited 4/15/2009 9:20 pm by roc
No expert on what you said but I agree! aluminum was considered to be a precious metal. AND it still IS and we throw it out by the tons in landfill..
I know of a way to make you all rich many times over...
Invent something that will find and pick out ANY Aluminum from the common garbage. Recycled is way more less costly way to do it!
Yes the Oceans are full of it but what a cost to extract it!
I have NO idea. However from a very old man that had to make gaskets for cars, and even Tanks in the US Army....
Somewhat subjective. I assume or think I know about.. A very small peen hammer and a careful touch can do it.. You CAN get a perfect ouitline. Now it is up to you to cut it out!
