My daughter and son-in-law purchased materials from Home Depot to refinish their existing kitchen cabinets. 1/8 inch self stick maple veneer for the cabinetry, maple raised panel doors, and maple drawer fronts. Since I have never done any veneering, I would like to know the best method for flush trimming the veneer edges.
Blackdome,
On the home page here there are some videos on veneering...and triming...it might help.
Blackdome,
I used to use a file but have switched to a veneer trimmer. Double sided. They have replaceable blades and can do both sides of the narrow edge of a board at once. You can get them at all of the woodworking catalogue. Rockler has one for $17.
The one thing I have found is that the edge still needs a little sanding after trimming.
ASK
I have found that, after trimming the veneer real close (1/16 inch or so) my low angle block plane works, just be real patient!
Is this prefinished or unfinished veneer? If it's unfinished, my favored way to trim it is to flush trim it with a router, after having run a strip of masking tape on the edge where the bearing will run, and then carefully sand it with an orbital sander. If it's prefinished, I would flush trim it as above and then put a very slight bevel on it with a 7 degree router bit, followed by carefully filing it with a handfile... just like you'd do with plastic laminate. The masking tape offers a protective barrier that will help goof-proof any slips as well as to prevent burnishing or otherwise marring the area where the router bearing runs.
"Rather fail with honor than succeed by fraud" - Sophocles.
Thanks to all who responded. Your suggestions are very much appreciated.
