I asked the guy who made this, but got no response.
I’ve seen this done in other boxes, but have not figured out exactly how to do it. Hopefully someone here can give me some direction.
It's an Incra Jig joint. Check the incra jig site for designs and video tutorials.
http://www.incra.com/
Jeff,
Looks suspiciously like an Incra Jig. Remember all those fancy ads in FWW 25 years ago with all the exotic woods? Bet that's what it is. I would assume that the joint could be cut on a router table using shop-made jigs.
Best!
-Jerry
As others have said it looks Incrafied. I think it spoils the look of that box and wonder if others agree.
Phillip,
While the joint is interesting, it is at the same time a bit garish. On the other hand, what better way to advertise to one and all the proud ownership of an Incra Jig. <gr> Made with much less contrasting woods, so as not to jump right out in one's face, might be OK. Bottom line: is it a box, or four corner joints with a box attached to it....
Best!
-Jerry
Philip,
I've never liked the look myself, either. Sure, the joinery's sound and unique, but not my taste. You're the only other person I know who doesn't like the look.Chris @ http://www.flairwoodwork.spaces.live.com
I see it differently. The look here is much too over the top, I agree. I am making boxes out of a bunch of bolivian rosewood I fell into, and I was thinking a very fine line african blackwood in those joints might be a nice compliment to the black lines that run through the rosewood. To each his own, I guess. It is all very subjective.
So, I respect your opinion, and in a high end box someone would a lot of dinero for, what would you prefer to see in the joints?Jeff
...."what would you prefer to see in the joints?"
I would prefer to see dovetails or mitres reinforced with slip feathers which are angled or straight.
If the dovetails have thin veneers of a contrasting wood on their sides this also is visually effective.
A lot depends upon the style of box and combination of woods so a multi fingered corner joint can look fine on one style but not another-same comment would apply to the use of the Incra type joint.Philip Marcou
Does this mean that we should stop waiting for you to do this with your planes?
One standing alone can be fun to look at every now and then. At craft shows you can see 50 of these boxes sitting next to each other. Those booths can be difficult to be around.
Take care
You can do the joint without an Incra jig. Essentially you make the first cuts oversize. Glue in contrasting wood and re-cut the joint to a smaller size. That leaves a thin line of the contrasting color.
Incra. I kind of like that, from a visual interest point of view. What I don't like is seeing forty of them next to each other. That strikes me as a testament to "I own this tool and its the only thing I know how to use."
FWIW, you can do that with dovetails too. Or other jigs, bought or made.
Real trucks dont have sparkplugs
How is this box joint made?
I would say a well made peg and fence for whatever jig you use...
My Incra can do it.. And then some.. Hand cut dove tails ...Maybe if you do it all the time AND cut with a saw on a really straight line!
Edited 5/26/2008 3:54 pm by WillGeorge
Jeff,
By the way, it's called an inlaid box/finger joint. I've seen it more often done with dovetails.
