I’m installing oak crown molding on the entire 1st floor of my house. The installation is going fine but I need to break the run where my stairs are. (The stairs go up thru an opening in the wall) I can’t say I’ve ever seen this topic before and can’t recall ever noticing how it’s done in other homes. How can I create an attractive termination for this angled molding that will hide the cavity behind it?
Mark
Stop at the opening and return the crown into the wall. Basicly its an outside corner but ends when it hits the wall.
I see it done two common ways.
1. Cut it off square at the end and fill the triangular hole with a suitable piece.
2. Neater is to let the crown moulding 'die out' just short of the outside corner by compound mitreing a piece as if you were going around an outside 135° corner. The moulding has to be compound mitred to fit where it dies out on the wall too. You end up with a wee triangular looking piece. Slainte.
Is this similar to how you end a chair molding by cutting the miter as if you're doing an outside corner. The little return piece is the face profile glued where the endgrain would be??
Sounds like I'm going to cut up a few bucks worth of oak crown getting it right--but if it looks like I image it should be real nice.
Yes, it's similar, and I think it is what Nigel suggested, where you end the profile as a right angle. My version of the ending is similar to his, but it's at 135° from the main run as viewed looking down on the run of the wall rather than at 90°, and mine dies out rather than ends abruptly. In either case there are compound cuts and dihedral angles to consider, but my suggestion is more complex and quite likely more mathematically challenging.
If you can do a search for posts by Joe Fusco over at Breaktime, he has some useful information on the topic. After I leave this, I'll do a search for links to his website and post it for you as an edit. Excellent information available there on tackling these tricky jobs. Slainte.
Edit. Link to Joe's site. Go to the calculations section once you've browsed around. http://www.josephfusco.com/
Some stuff I've made.
Edited 11/27/2002 12:20:37 AM ET by Sgian Dubh
Slainte,
Looking forward to trying this out after the weekend. Maybe a couple weeks after--been working hard to get the house presentable for company ;-)
Mark
As a plasterer I somewhat biased ;-), but Plaster is much better for crowns and coves then wood. It doesn't care about flaws, contours or imperfections with the walls or ceilings. Also buying it from a local plasterer that has run it on the bench for you can be less expensive then wood. Of course that would depend on how intricate your crown is. With most plaster forms, intricacy is irrelevant. Never a problem with mitering either!
Don
What about a decorative block butted against the end of the moulding? I used this method on the corners of a room with crooked walls and really liked the look.
