I have a Jet JSG-96 disk/belt sander. How do I remove the graphite pad in order to replace it. I have the replacement, I just want to check to see if there is a simple way to remove the old.
Alan – planesaw
Alan – planesaw
Hair dryer or heat gun to soften the adhesive and a plastic putty knife to lift the old pad. Clean up any remaining adhesive with mineral spirits.
Men will never be free until the last king is strangled with the entrails of the last priest.
~ Denis Diderot
Thanks. I'll give it a shot tonight.
Alan - planesaw
Doug,
Your suggestions were excellent. Thanks! Here is what I found. In my case, the heat gun didn't help get the pad up. I found that once I used a putty knife to pull up a corner of the pad that I could pull it off rather easily.
That left all the adhesive on there. Started with the heat gun and that was taking a long time. So, I simply began to soak the adhesive with paint thinner. It was then easy to wipe it off, get it clean, and apply the new one.
I am back in business. Thanks again!
Alan - planesaw
Glad you are back up and running.
Don
Thanks.
Now, new issue. I put a new sanding belt on. 6 x 48. How long does it take before it runs in the center? I know how to adjust side to side, etc., but it won't stay in one place. Tried another one, same thing. Do they have to run for a while before they wear in, so to speak?
Alan - planesaw
I usually have to adjust mine a half a dozen times before a new belt settles in (smaller adjustment each time). The new graphite pad may be a little taller on one side and aggravate tracking but it should even out pretty quickly with use. Is it mistracking to one side or both? If both try adding a little more tension.
It goes from side to the other. I make minute increments, but it gradually moves over too far.
When you say adjust the tension -- where, how?
Alan - planesaw
Do you have the orientation correct? They are designed to run in one direction.
Jigs --
One of my "older" sanding belts has arrows. The newer ones do not. Is there a way to tell which way they are to run?
Alan - planesaw
The orientation of the splice is how I tell when there is no arrow. I looked at the manual for your machine and there does not appear to be an adjustment for tension.
Thanks for sticking with me on this issue. "For the funny of it" I turned the belt around. Tomorrow night I'll see how it tracks.
The splices on these belts appear to eliminate the direction issue. Instead of overlapping, they have a splice holding the two ends together on the same plane (make sense?).
I may call Jet and see what sort of an answer I get from them -- assuming they have some sort of customer service.
Alan - planesaw
