Hello all! I want to stropping and I would like to know if you have to add water to the honing compound when you are stropping.
Jack
Jack
I never do.
Me either.
Gatordoc
I use a paste type metal polish instead of the dry honing compound. I like Simichrome, Maas and Mothers. Wipe off the strop when you are done. Once in a while you can clean it up with a little mineral spirits. The polish out performs any compounds I've used.
I've never found it necessary, and have actually never heard of it either. I can't see any benefit, as there is no swarf to wash away (EDIT) or lubrication necessary.
Edited 12/1/2008 10:54 pm by flairwoodworks
Let me say this about that. I don't carve much but investigated stropping thoroughly for knives and my plane blades. For the yellow brick of stopping compound I scrape the brick with an old file or the end of a ceramic sharpening stick to get a dusting of powder onto the stopping surface and just use that dry on the leather. Works great. Why the heck they don't just provide the yellow stuff as powder I will never understand.
( about the only use I have found for the sharpening thing with the two ceramic sticks and the block of wood. )
Diamond paste on a maple block of wood is another good way to go.
This is one of the best investigations of sharpening systems I have ever come across. She investigates stropping materials a fair amount
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2793
For plane blades and knives I have dropped stropping and just use water stones up through 8000 grit.
Hi Jack
The easiest to use is the Veritas green rouge (looks like a green crayon).
Rub it onto either hardwood or leather and add a few drops of baby oil (mineral oil). This will soften and spread it smoothly.
Thank's Derek, Thanks for the information, I am a always looking for new to sharpen my tools, I do not like to work for nothing. I like my saw to be sharp, and my chisels to be in top notch shape, so the tool cuts the wood and not pull it apart.
One other thing I do a little turning and I would like some idea's on sharping the tools for turning, could I use the honing compound.
Thanks Jack
Not neccesary to hone turning tools, maybe a skew because it works like a plane. I use a 120 grit friable wheel and turn right off the wheel.
mike
Me too.Chris @ http://www.flairwoodwork.spaces.live.com(soon to be http://www.flairwoodworks.com)
>Baby oil
Is that what I am suposed to do with the waxy green one ! I thought it was only good for a buffing wheel. Friction heat it up and melt it on. Thanks.
roc
Edited 12/2/2008 7:55 pm by roc
I condition the leather wheel with light machine oil in between applications of polishing compound. The compound works its way into the leather. I only recharge the leather as needed.
Greg
Exo 35:30-35
