Hi All,
I have a bench model hollow chisel mortiser and have been making 1/2 ” mortises in American White Oak. Now this is hard yakka for this little machine. Is there a recommended setting for the drill bit dimmension below the chisel points ? I thought I read somewhere that it is different for hardwoods as opposed to softwood.
Thanks for your help
Stephen,
I hold the bit down between 1/64" and 1/32" from where it bottoms out in the chisel. Others may have different preferences. Too little slack, and it will run hot, too much and chips will bind instead of being pulled up the flutes of the bit.
Having the bit and the chisel sharp will make a difference in how it cuts. You can use carvers' slip stones to hone the bit's cutting edges and lips, and a pointed grinder on a 1/4" shank chucked in your drill will take care of the chisel's inside edges. Stone the outside flats LIGHTLY on your bench stone to remove any burrs, you don't want it to be tapered!
If it is getting really hot, try slowing down the bit speed another notch or two. Half inch mortises in white oak is hard going.
Cheers,
How do you do this with a BT machine?
"Everything should be made as simple as possible, but no simpler." A. Einstein
http://www.albionworks.net
Edited 8/3/2004 1:20 pm ET by AlbionWood
Albion,
Dunno, I mortise using a drill press; it has step pulleys...Those bench top machines are one speed?
Cheers,
Yes, they are direct-drive."Everything should be made as simple as possible, but no simpler." A. Einstein
I hope you guys are not going straight down !
Plunge about 1/8" and come out, keep doing it till you are at the set depth.
Give the drill the time to clear the chip, give the chisel a little break heatwise, the harder the wood the shallower the plunges.
And then there is the horse power question !
C.
Stephen,
We use a dime as a spacing jig when installing the bit & square chisel in the mortiser - the thickness of a dime seems to be just about the optimal distance between the bottom of the chisel and the bottom of the bit.
FWIW, clear the chips frequently and watch for overheating during use.
Good luck,
-Jazzdogg-
I also do a lot of mortising in WO and 1/2" is definitely pushing the capabilities of a BT machine. Even if your bit starts out sharp, WO quickly takes the edge off and can even curl the points. Most of the time I use a 1/4" chisel and make two passes. Lot less strain on both man and machine that way... I was getting a sore shoulder and stiff neck from pulling that handle to force the 1/2" bit into the wood.
FWW did a review and proper setup of this type of machine,don`remember which issue.
