I need some help identifying an exotic hardwood I think comes from Africa. It has the appearance and the same properties as teak but I was told it is ECKAY?????? I have not had any luck searching the web trying to find something that sounds like this.
I also need some advice about glueing this wood as my glue joints aren’t all that strong.
Thank you ,
eliza
Eliza, you may be thinking of "ipe." I believe it's a South American wood, but I know that it's coming into greater usage here in the U.S. for outdoor furniture, decking, etc.
If you do a search here on Knots or on the web, you should find loads of information regarding properties, workability, etc. I know for a fact that there have been several threads on the topic here.
David
Look, I made a hat -- Where there never was a hat!
Eliza, I'm pretty sure the wood you are dealing with is ekki; Lophira alata. It's an exceptionally dense, African species used for heavy construction, mine timbers, docks, pilings, ect. It is extremely stong and decay resistant, but not particularly stable for fine work. Because it is so dense, it's difficult for glue to achieve a mechanical bond, but its extractives don't pose any significant chemical problem with respect to glues or finishes. It's absolutely brutal on blades...so try and avoid projects requiring much shaping.
Edited 10/25/2002 5:28:04 PM ET by Jon Arno
Edited 10/25/2002 5:29:00 PM ET by Jon Arno
Thanks for the info, you guys always come thru'.It's really nice to have such a wealth of info at my fingertips.
It is ekki and I was able to find lots of info once I found out how to spell it!
Eliza
Jon, you never fail to impress! Have a good weekend.
DavidLook, I made a hat -- Where there never was a hat!
