43402.1 | |
Matt, I have one for you:
I just bought the Porter Cable 2412 Dovetail jig to do blind dovetails for a bunch of drawers for a vanity. I’m sure I am missing something simple. Here’s the problem: the drawer back is 1/2″ shorter than the sides, so that I can put bottom mounted slides on. When I cut the dovetails for the left side – no problem, the top of both pieces are up against the gauge (set after I center the drawer side) at the correct placement (i.e., the top edge of the drawer bottom is over to the left past the top edge of the drawer side. This results in the top of both pieces being even. Problem is that when I go to do the other side of the back by flipping the piece around, the top of both pieces is now not against the gauge – i.e., the bottom of both pieces are against the gauge. This doesn’t work because the bottom of the back is not flush with the bottom of the right side. Any ideas? I have tried taking a block equal to the 1/2″ difference and putting it against the gauge and the back and between the gauge and the bottom. Didn’t work. I am also going to try posting this on the Knots forum. Thanks in advance for any advice | |
I'm not too familiar with router dovetail jigs for blind dt, but the first solution that comes to mind is the one you already tried: put a 1/2 in. spacer into the jig to offset your workpiece appropriately. I can't imagine why that wouldn't work? Is it because the dovetails aren't properly spaced in the width of the board? If so, perhaps you can relocate the guide to accommodate. What about this method doesn't work.
Write back and let me know so I can take another stab at this.
- Matt
Matt,
Not sure I understand why it didn't work either. At one point I just gave up in frustration. You may be right that I didn't have the piece centered between the fingers. I am going to take a closer examination this weekend and will let you know. Thanks
rc
