Hi, this is my first post, Im kind of new to woodworking and first I want to thank everyone, Ive been learning a lot from just reading the posts in the forum.
Here are my question..
I need a compressor and Im trying to decide between these 2,
3hp Ingersoll Rand
modelSS3L3
60 gallon –
1 stage –
135 max PSI –
ACFM @40PSI 11.3
$680.00
http://air.irco.com:80/IS/product.asp-en-12885
or
5hp Ingersoll Rand
model2340
60 gallon
2 stage
175 max PSI
$1,500.0
http://air.irco.com:80/IS/product.asp-en-12878
Im just starting a small bussiness mainly making kitchens, for now I will be using the compressor with a Porter Cable PSH1(I think thats the model) HVLP spray gun and with a Sander.
For now I think that the 3hp is more than enough, but in the future I dont know, what would you suggest, the 5hp costs a lot more but in the meanwhile its seems more industrial than the 3hp model , so besides Horse Power thats another consideration, do you think the 3hp model is a consumer grade comp?
Another option is that since the 3hp comp costs half of what the 5hp costs, I can buy the 3hp now and in the future if I need more air I can buy another 3hp..would that be a good option?
Lots of questions.
Thanks in advance for your help
and sorry for my english.
Ramon
You can answer your own question if you look at the cfm output of the compressor and compare the cfm needs of the tools. The new Festo electric sanders are pretty slick. Does it make sense to fire up a 5 hp motor to run a small sander. True air sanders do do run cooler and last longer but you did point out the savings of 3 hp versus 5 fp. Sanders and spray guns use a lot of cfm. Binks, I beleive has an HVLP gun that will run on a 1-1/2 hp compressor. You could also get a turbine driven gun. Learning how to do the research will pay off big time over and over. The $500 you saved can cost more in the long run.
In my experience 3 hp isn't enough and comparing cfm usage will tell you all you need to know.
As Rick mentioned, think ahead rather than just a single item. You'll find that having adequate air (AND reliable) is something you'll depend on in a production situation.
IR makes great units, you can also get one heck of a good unit in a Quincy compressor also.
I've recently heard of a guy who got a 5hp Quincy unit with a baldor continuous duty motor for $900. That's a song for work horse that will likely outlast him.
Do some research, and make sure you buy what you may need, not what you think you need today. The difference in cost is a little savings today, sure... but consider how much an upgrade will cost later if you underestimate your needs.
Air tools are awesome fast, but I prefer electrics due to dust collection abilities. Fastener Guns take next to nothing to run also. Where you'll find a significant CFM demand is in spray finishing w/ production guns. Those consume from 9-15cfm as a conversion HVLP.
This isn't one of those tools that you want to skimp on :)
Consider a dryer and auto drain also if it doesn't come w/ one.
michael
Thanks for the Help!!. The distribuitor of Ingersoll Rand in here gave me a catalog of their air tools, Im in the process of reading the specifications of their tools to try to calculate what my air needs would be in the future. I hadnt consider a production situation so that was a real eye opener, its in that situation when you most value your investment.Thanks!!
What you will need to do is look at your anticipated air needs. This will include how many air tool you will have and how many will run at the same time as you expand your shop. In a production shop as more people are added your air needs will increase as well if you are using multiple air tools for finishing and sanding. If you think you will have someone in a spray booth and someone sanding at the same time you may be better off with two 3hp units, one for each operation. If you will have two people using air sanders you may want an 80 gallon tank rather than the 60 gallon you are looking at. You just have to determine what your plan is and go from there. A one man shop with only one air tool running at a time the 3hp 60 gallon unit is plenty for just about any spray gun or dual action sander. But if you expand the number of tools running at any one time then that may not be enough air for your shop.
Good Luck!
I personally would go for the 2 stage over the single. Any commercial air sander far exceeds an electric but they are air pigs. The big advantage of 2 stage is that at 90 psi a single stage output really drops where as 2 stage there is very little difference. Go for the largest compressor you can afford especially if you are considering doing it for a living.
Brian
