I was out in the shop last night testing what I thought would be a great new vacuum bag design, but things didn’t go as planned. My design used a frame with vacuum bagging material stretched over it, and closed cell foam around the bottom. The frame is then placed on the platten, clamped down, and a vacuum is drawn, eliminating the need to wrestle a large panel into a bag. This is similar to some industrial vacuum veneering systems, but simplified for a home shop.
The problem I have is that I can’t pull much of a vacuum. Obviously this means leaks, however they must be small cause I am having a hard time detecting them. Have any of you built a similar system to this, and if so, could you share your experiences on making the system seal up properly.
I’ve already got a couple of the typical style vacuum bags that I’ve made, but veneering big things worries me, as it’s a hassel to get everything into the bag, and I don’t want to risk some delicate veneer that I will be pressing onto some large cabinet doors.
Andrew
Fine Woodworking Recommended Products
Preppin' Weapon
DeWalt DWV010 HEPA Dust Extractor
Craftsman CMEW213 Belt Sander
Lee Valley Pocket Marking Gauge
I've never done any vacuum bagging, but I do have 18 years experience in the high-vacuum industry. If I understand you correctly you've made a bag that is half vac bag material, and half closed-cell foam. If this interpretation is correct what you most likely have is a ton of what are known as "virtual leaks". These are small spaces containing air and water that are completely within the vacuum space (that would be the closed-cell foam). On top of that I suspect that the closed-cell foam is not all that air tight.
I was surprised to learn that many CNC Routers (the big computer controlled "cut the project out of a sheet of plywood" machines) hold the wood in place by vacuum.... THROUGH A SHEET OF MDF. So obviously some of the materials that I thought were rather air tight (like MDF) are far from it.
I don't know about closed cell foam, but you might try a layer of vinyl that is known air tight over the foam or other materials.
________________________
Charlie Plesums Austin, Texas
http://www.plesums.com/wood
Andrew, I have done lots of projects that just will not fit the standard bags, and what I usually use is carpet tape and vinyl to build the bag around the work. I keep rope-caulk on hand to stuff into any wrinkles and around where the hose goes in.
The tape I use is 1.5" wide cloth. Don't use the plastic film tape isn't sticky enough, and the fiber-glass type leaks. I usually get 28" Hg without any problem.
I have been getting request to teach another weekend workshop of my methods, which will probably be sometime in Jan - Mar.
