I have never worked with Osage Orange. I recently bought a 3x3x24 block for the purpose of building a couple of planes with it . The sawdust after jointing felt like it had a lot of oil.
The wood felt very slick like it is has more oil than other woods. What glue has worked better for you in gluing osage orange?
I've never worked with orange osage, but recently laminated two pieces of lignum vitae which is plenty oily. I wiped down both surfaces with methyl hydrate, then glued together with Titebond III. It's been a few weeks and no signs of failure yet.
Good question. I fool with it quite a bit for tool handles, walking sticks and other things but have not glued any. Forest Service manuals say it takes glue well.
J
swifty,
I recently made a plane in osage orange, with ebony sole. I used titebond for that, no issues. Also, have used some osage in stripper canoe construction, glued with epoxy (west systems). A friend has made bows out of osage, I believe that he used hide glue to apply reinforcing deer sinew to the outside.
If you are worried, I'd recomment making a trial lamination with the glue of your choice, and see how it does. Your mileage, as they say, may vary.
Very nice work! I am thinking of using Osage Orange with a sloe of African Blackwood.
Very interesting. I have a lot of Osage here -- use it for fence posts -- but as mentioned, have also made tool handles and other things from it. the density, toughness and stability have always seemed to be a good combination for planes. Are you satisfied with it as a plane wood?Joe
Joe,
I haven't used it enough to tell. I don't anticipate any problems. The osage was a chunk of firewood that I squared up and left to dry in the shop. Checking was minimal, and the billet was still square when I picked it up to make the plane body years later, so I take that to mean it's pretty stable. It's hard as a bone, tho with the ebony sole, that doesn't make any difference in this instance. I'd think it would wear well on its own.
Yeah I have built quite a few things out of Osage. I've used Titebond and epoxy and plastic resin glues on it with success with all of them. I would forsee any problems with any of these glues.
Kaleo
http://www.craftsmansbrew.wordpress.com
I have made a few bows with osage, maple, hickory and Ipe in various combinations. Titebond III is the glue of choice for the laminates, I have never had a failure.
thanks for the info on Titebond 111. I have it as well as the original
