Is it possible to glue one species of hardwood to another. An example would be a table top with maple and walnut alternating. What considerations or rules of thumb should i follow. Thanks
Ivan,
It's done all the time and with those specific woods...chess boards. Just make sure you start out with well seasoned wood and leave enough room for expansion and contraction.
ivan,
I make cutting boards and chessboards out of mixed woods all the time. I use maple together with cherry, walnut, padauk, mahogany, and other woods. It's not only possible -- it's a great idea!
Attached are some examples I've made.
I've got some examples of quilted boards and reverse-stripe boards as well, if you're interested.
Edited 2/7/2005 9:21 pm ET by Matthew Schenker
That is one fancy cutting board. The contrasts between the woods really makes for an exceptional cutting board. What exactly is a reverse stripe? Thanks Ivan
ivan,
Reverse stripe is kind of my own term. It's a striped cutting board that has been cut across from corner to corner and reglued after flipping one of the halves. When you do this, the stripes form a right angle. Your eye follows the stripe pattern to a point, then it reverses.Beloe are pics of one of my quilted boards and a reverse-stripe board.
Those are beautiful cutting boards! Would the wood in the reverse-stripe board be maple, mahogany and walnut?
Those are the woods! The one you see is actually an early prototype I made of reverse-stripe boards, but it was the only picture I had. I made a few of these boards during the holiday season, but they sold pretty fast and I didn't get a picture of them!On the original subject -- this shows that woods of all kinds can be glued together successfully.One caveat, however, is that some woods are a little more difficult. I find Padauk to be a bit of a challenge. But once it's glued, it holds beautifully.
