I need to glue on a large (8′ x 8′) frame on a built in cabinet set. 3 top openings and 3 larger openings on the bottom. I’ll be using pocket screws to secure the frame. However, there is almost 60′ of glue lines that needs to be put on at the same time. I would do this differently the next time but this is what I have to deal with now.
I was wondering which glue would be best for this job. Frame is cherry with 3/4 baltic birch sides that will be joined with pocket screws. I just need a good glue that will drip less than others since there will be plenty of time for the glue to drip before all pieces are covered and the frame can be put in place. What is a good wood glue that is thicker and may drip more slowly?
I did mask all the squeeze out areas with painter’s tape. And plan to screw threw the face of the frame at top and bottom where additional molding will cover holes, as well as use a few face frame clamps to get it held in place prior to screwing in all the pocket screws.
Thanks for the help,
Scott
Some times these things just come to me.
Pocket screws you say ? Aaaaaaaaauuuuullll right.
That has Norm written aaaaaaaauuuuullll over it.
So . . . I asks my self "What would Norm do ?" and I answers my self :
http://www.amazon.com/Liquid-Nails-LN950-10-Ounce-PolyAdhesive/dp/B000BO9PA6/ref=sr_1_1?ie=UTF8&qid=1331425986&sr=8-1
Or . . .
you could invite the local boy scout troop over or, if it were me, one of the local cheer leading squads . . .
and arm each one o' them with a bottle of Elmer's and when you say "GO" they all at once smear some glue on in their assigned place on the frame and badda boom badda bing you quick set the frame in place.
If you use epoxy, there are additives (colloidal silica) that let you make it as thick as you want. Special hardeners can slow the cure speed so there's more time to apply. Mixing large batches can be problematic because the reaction causes heat which accelerates curing and reduces pot life, but that's relatively easy to remedy by making smaller batches that get used up promptly.
I'm being only half serious hear but
Seriously :
if using the epoxy, which is a great idea, you can make a large batch with low heat if you mix it on a large flat area like a cheep plate that way the heat dissipates (and ironically won't cure faster ) rather than builds up (and does cure faster ) if it were mixed in a cup.
Half seriously :
Did you see the price of the liquid nails ? Four bucks for that huge tube vs like a whole lot of $ for a smaller quantity of epoxy plus the $ for thickener stuff.
less glue, less drip
The trick is to apply the right amount of glue in the proper manner. For that large of a glue-up, you might consider an applicator with a built-in roller/spreader.
Shades of Norm once again
All roads traveling modern wood working lead back to Norm.
Norm is it
Norm is all
All hail The Norm
Normmmmmm Normmmmmm Normmmmmmm
PS: all Norm type discusions should include the holy word Biscuit so . . . there . . . I evoked the holy utterance.
Answering Questions
Folks write to forums to get answers, not to be ridiculed in their ideas. If I have a problem and it isn't answered, what good is the forum? I don't write in to get a laugh or to laughed at. It seems to be in vogue to trash Norm Abrams, as if that makes one a professional. At least Norm taught people some skills and gave them ideas. What did your answers do? Evidently they made you feel good about trashing Norm, but otherwise they were worthless.
this is what happens
when one doesn't really know the answers, they try and resort to wit.
ron
. . . and . . . ah . . . sid . . .
I seem to have missed YOUR solution to the OP's question.
Maybe you could add your refreshingly original suggestion.
( again )
for those of us who missed it on the first opening few volleys of post by those who ACTUALLY
>really know the answers<.
That was you up there leading the charge right ?
sorry
I am not just quick with the mouth like you are.
there are more than likely a handfull of way to do it efficiently, but one would like to observe the the environment first. to see what one has to work with. I doubt that it would be difficult to overcome.
ron
Apology accepted
>one would like to observe the the environment first.<
take all the time you need
We'll be here. I can't speak for the OP however; he may want to get a solution and get back to work.
always
have to be the wise ass with your replies'
he could have shown some pictures of his situation to emphasize what has to be done.
ron
Yes
I wan't really apologizing
to you ; just that I didn't have a quick mouth like you!
ron
Seriously
You can't believe that Roc doesn't know the answer. Someone not familar with the folks here won't understand the humor.
No one has riducled you - lighten up - just a group of Friends here with very good skills willing to help always but with sometimes questionable off-the-cuff comments.
SA
Yep too strong on the comments. You're right
>questionable off-the-cuff comments<
I feel like SOME THING happened though. The OP (Scrappy1 = Scott) actually carried on a conversation
Oh wait
That was Bannerpond perhaps channeling Scrappy1. Or some stuff.
So often the NEW people sign in , get their answer on demand and sign out with out another word. It is as if they think we are on THEIR payroll.
I think I have mellowed though. Haven't I ?
Don't answer that.
Wait until he tangles with Larry. Oh my gosh.
yes , but he usually
always seems to practise it on new people to the board. I understand that he doesn't appreciate 1 timers to the foum and by his comments as noted by the OP they are not going to come back. Hee is not giving them a chance. if he doesn't like them then don't answer them. it is quite rare that there are not questionable off the cuff comments in his threads rather than sometimes.
ron
I Think She's Not Going To Get Up Again
Ya may as well take the bridle off of her.
who the
fuck does anyone even know what you are talking about
ron
Such language dear me.
This horse is dead. Stop beating it. Take the bridle off of the poor beast and go find another horse to beat.
As in "Don't beat a dead horse".
Or better yet "Stop beating this dead horse ".
Just trying to provide something with a modicum of interest for those who are tired of this drivel. I know I am.
Maybe we can get this back to woodworking since Sid is still surveying the terrain to help him think about his solution.
aahh at last, thank you.
Scrappy1(Scott),
Ok to chime in . . . tell me how much you like pocket screws an how I am full of something unmentionable. Heck I never even installed one with the jig and special drill bit and all. Maybe I am missing out.
Anything, about woodworking, please.
always the big mouth
I don't really know whether you can speak about woodworking or not without injecting some sort of sarcasm in it
ron
Since you asked "What did my answer do" Lets run with that
Why wouldn't liquid nails work just fine ? It is a viscous glue. It is not going to drip.
Why wouldn't the group glue application work ?
By the way I was serious about the Elmer's. Their white glue is excellent and inexpensive. I have done extensive glue testing and it is a gem.
I seconded the epoxy solution a bit pricy but an excellent solution.
FINALLY
In closing let me say and be vary clear so there is no question about my position on Norm Abrams :
I have watched his shows for a hunert years and always enjoy them. He takes you to experts or museums and suppliers and still builds solid furniture all in a half hour.
Norm is great.
Norm is not building "FINE" furniture. Though.
So keep that in mind. Norm is building geeter done with power tools furniture.
That's OK that is great.
Seriously pocket screws are are totally a Norm show tool.
Norm would have used another practical solution that may not be from the old world traditional tool box. A modern glue and a modern applicator.
For glue with some thickener in it that means a caulking gun. Hard to squeeze out of a bottle if thickened. Hard to get it to the spout end from the bottom of the bottle. Sooooo it has a plunger.
Norm :
I have read his auto biographical book Measure Twice Cut Once.
Have you ?
Read it more than once as a mater of fact because I enjoyed it so much.
Post of me praising Norm or recommending members of this chat room to review specific shows and techniques :
http://forums.finewoodworking.com/node/89466
http://forums.finewoodworking.com/fine-woodworking-knots/finishing/seeking-high-quality-exterior-clear-coat-recomendation
http://forums.finewoodworking.com/fine-woodworking-knots/general-discussion/how-mailbox-post-constructed
http://forums.finewoodworking.com/fine-woodworking-knots/general-discussion/uphostery-aaargh
I could find more
There is fine woodworking, which is the title of this here whole sheebang and there is Norm woodworking.
That's just a fact Jack.
What have you finally come up with to solve the problem ?
PS: Thanks for Defending Norm Abrams and Kicking the butt of anybody that says he is not a huge asset to helping people learn good basic woodworking.
Actually, Norm has the solution
Norm does have the answer; very eloquent indeed! He did an episode building a set of kitchen cabinets. He cut a slot in both the face frame and boxes (full length of both at all joining surfaces) and assembled with glue and biscuits. I think this reduced the glue volume and made for a very stable assembly in what could be an awkward procedure. You may be too late for this system but keep it in mind for the next time.
Anyone who ridicules Norm needs counseling. Norm is a regular guy who helped millions of folks with woodworking and home repairs. Yes, I cringe sometimes when he brings out the nail gun but we all have our favorite assembly systems and a nail gun does not make anyone a bad person or unskilled woodworker. Even my friends, who do not know what to do with a screwdriver, know who Norm is - and here we refer to him by first name only and everyone knows who he is. He may have critics because jealousy is a very powerful emotion.
How about double-stick tape?
FastCap makes "SpeedTape" which seems to be designed for just what you're doing. According to their product description, ' 2" works great for face frames'. The company refers to it as "Contact cement on a roll". I've not used this particular product, but I've had good results with other FastCap products.
3M also makes a double coated tape for Woodworking
. Adhesive goes exactly where needed without masking, brushing, or spraying
. No Set-up, clamping, equipment, or drying time
. No liquid mess, overspray or odor
. For use on particle board, melamine, HPL, wood, plywood, vinyl, foam and mo
. Application ideas include" edge banding, refacing cabinets, applying wood veneer, etc.
Liquid Hide Glue
I would use liquid hide glue and Pin nail the face frame till it set. Hide glue has good open time and nearly as strong as the modern PVA glue.
But the Fasttrack tape is also a good idea. That stuff is is super strong but not better than the hide glue.
