I’ve some scrap pieces of man made solid surface material{Corian etc.)that I would like to glue up, to make a small interior window frame, to dress up a window I installed in a bathroom. Any one have any idea what glue would work best in this situation that would be available on the open market. It’s a solid cream color. Any tips would be appreciated.
Edited 6/26/2009 3:28 pm ET by brownman
I get all my stuff black market . . . so . . . guess I can't help.
Never mind
roc
Formica sells a "seam fill kit" for their solid surface product, colored to match. I think they sell clear as well. It is a two-part acrylic resin. I wish I could help you more.
I've used clear two part epoxy and its holding up in a shower with dayly use. 6 years on!
Clamp well and use a thin layer and clean off all marks and writing! It will show!
I would suggest trying epoxy. You can colour it to match.
What I would try is to make a test joint let it set for double the recommended cure time and then test the joint strength. (pull, twist, tap with a hammer). If it holds now then it will hold for a long time but if the joint is at all weak it will separate very early, even in static conditions. YMMV.
Some tips from a shop monkey that makes countertops from the stuff:
Increase the glue surface. In some instances we use a router bit that makes the flat butt edge a wavy butt edge and the other edge gets the same interlocking treatment. You could do it with any two matching router bits (think rail and stile). We commonly use butt joints with the proprietary acrylic resin glue sold with the product but if you use any other glue then I would advise a larger gluing surface.
Clean the joint well with alcohol. be sure there is no pencil or other marks or writing on the joint it WILL show. The alcohol removes the grease from contact with your fingers.
Be sure the piece is well supported. When making a countertop with a drop edge on the front, we back it with a piece of plywood or mdf siliconed in place. I wouldn't use mdf if you can avoid it, and depending on the size of the window you may not need it. Be sure that during installation you support adequately with shims.
WEAR A RESPIRATOR while sanding this stuff. The dust is hard and sharp (think silicosis).
All that said, others suggestions about two part epoxy and colorant, as well as making a test joint are excellent advise.
Good luck!
Thanks to all for the gluing and safety advise, when working with solid surface. I was originally thinking that I would use the two part epoxy, since the seam fill kit is expensive considering I only need a little. The two bathroom windows are only a few feet wide and less than a foot tall.
