Any recommendations which type of glue to us for a maple cutting board? My inclination is to use polyurthane.
Polyurethane = bad
PVA (Yellow) = good.
Best,
John
Kenneth I have used urethane glues for these dozens of times with great results, but just about any water resistant glue works fine, and before I get attacked - any wood glue will work. but water resistant glues last longer.
Dan
I prefer Titebond II, a PVA glue. I gave a cutting board to a friend, I found out the other day that she has been running it through her dishwasher for several years and it is still together. I don't recommend this kind of abuse for a wood cutting board but do recommend the glue. No I don't work for Titebond.
Thanks to everyone for the advice. I agree that Titebond III is probably the best option due to its tendency to creep and adjust for the wood movement. I know that it is advertised as "water resistent" but not water proof so I wasn't sure that it would stand up to repeated cleanings in the sink. However, is sounds like that should be no problem.
Thanks again!
Titebond III is advertised as being waterproof. It's Titebond II that's just water-resistant.
I would use Titebond II or III. 30 years ago I made a maple cutting board using regular Titebond yellow glue and the board is still in great condition even after being used almost every day and wiped with damp cloths and sponges.
Dear Kenneth,
Titebond 3 would be my choice.
Best,
John
Titebond III
Titebond II or Titebond III both work well and are sufficiently water resistant.
I use Titebond III, as it is waterproof. One added benefit is that it seems to have a bit more set-up time than the II, so that I can fit all those pieces together before it sets up.
My $.02..............
Rich
