Good morning all. I just became the owner of a Freud router table system ( Birthday gift) and I have two questions: a) The manufacturer recommends that the exposed surfaces of the MDF be sealed if the temperature gets below a certain minimum ( 5 degrees C) or the humidity above 65%, both of which may apply here. My question is what should I apply as a sealant. I dont want the MDF board to start blowing up like rezflake in water. b) I need a router for the table and the antique Black and Decker I own certainly won’t do! What do you think of the Freud router model FT2000E?
3 1/4 hp with 1/2" collet & 1/4" collet reducer, Micro-Adjust knob, and Quick Adjust Depth Gauge 15 amp motor .. Can't be all that bad for less than $200.00! I have never use that brand but I have looked at them.. Seems like a nice tool to me.. BUT again I don't have one..
I use MDF for alot of stuff around the shop..
I usually attach a hardwood edge (glue and spline) or just seal the edges with yellow exterior glue that is rubbed into the wood..
As for the surface I just keep a coat of Minwax Paste Finishing Wax.. (Also on my TS top..) Seems like a nice hard wax and I have no gripes using it. I wax them after every use.. Takes little time..
Chicago here so we got EXTREMES of everything.. Even with the edges unsealed I have never had a problem with MDF used in my shop jigs etc.. But most are sealed as in above..
Thanks ever so much. The wax finish will certainly keep moisture and everything else out. BTW, I had sent an email with my question to the manufacturer, and now, I don't need to wait for an answer that probably will never come!
I have the Freud FT 2000 E router and it has all the power I could ever want; it has never bogged down in an edge cut or in a plunge. It has a soft startup so the torque won't jerk the machine out of your hands. RPMs are adjustable with a knurled dial. Plunge depth easy to adjust. 3 pre-set depths can be set. There is a micro-adjust plunge depth knob as well as a lever (right hand) to lock and maintain the plunge level once reached. On/off swith is easily accessible with the left hand. Springs get much stiffer as the plunge gets deeper. At around 14" tall, you'll need some space under the table, and a stiff mounting plate since it has some heft.
It was a great investment for me at around $179 a few years ago, and I can't see I'll ever need another one.
Thank you for your comments. Very reassuring. Sounds like a "buy" is in the cards. Any doubts I had as to value for money are certainly alleviated. There are so many kinds to be had and all have something to recommend them, I guess, from celebrity endorsement to the guy at the hardware store who swears by DeWalt only, so I was a little overwhelmed when I decided, after my present machine proved to me beyond a doubt that it was no longer sufficient for the precision work I want to do, to look for something better. I have also grown very weary of bargain tools that cannot be set up or controlled with a precision better than 0,5mm in hard stock, so one ends up waisting both money and precious wood.
