Hello everyone,
I have a couple of questions,
1)I now use what i call disposable fluid lines for my two gallon pot. Disposable cause it was free, 100 ft roll of 3/8″ of vinyl tubing, well the free stuff is coming to an end. Are regular fluid lines made of a material that is easier to clean ? and can I use the blue flexible polyurethane air hose for fluid lines. (since I have a few broken hoses with broken ends)
2) Does a finish that stays in the pot for a day or so stay “fresher” under pressure ?
3) Can you set up a gravity fed hvlp to be pressure fed… The only reason I ask is at a resent wood working show I saw Appolo’s new A7500c gun. It can use a pressurized cup, a gravity fed cup and can also be pressure fed. Obviously the fluid line would enter from the top.
I think that’s it for now…
Hope everyone enjoyed the weekend,
John
jpat
. are proper fluid lines easier to clean?YES
.can(should) you use blue flex line as a fluid supply? NO
2) YES
3)YES
