I have made new raised panel doors for my sister-in-law. The stiles and rails are maple and the raised panel is 5/8 MDF.
I am not going to finish them for her, but would like to know what to recomend to her to make sure the one who does, does it right.
The maple makes good S&R’s but the MDF is used mainly for the economy and stability. The MDF, even with sharp bits, have a slightly fuzzy feel and I am sure needs specific primer/paint application to reduce or eliminate the fuzzy look at finish.
I would appreciate recommendations as to how to prime the doors so that the finish will be as good as can.
I have not glued the doors up yet and would like to know if the MDF lessens the problem of glue from the S&R’s coming in contact with the panels.
MDF doesn't move as much as real wood with humidity swings but it doesn't hurt to leave the panels unglued so that they can float, especially on the larger panels.
John W.
Thanks John.
I had not planned to glue up the panels but since the joinery on these will not be M & T, I want to make sure there is a good application of glue where the S&R cuts are joined. I was just wondering if a little squeeze out on the MDF panel is anything to be really concerned with.
Cool
A good shellac based,tinted primer like Zinnser or Kilz would be my first choice. It dries harder than latex, and therefore it's easier to sand the fuzz off. I am assuming this is paint-grade work since you're mixing mdf with maple.
For a finish coat,there's a big variety, but I'd use a glossy oil based paint, for durability and ease of cleaning.
Jackplane,
The doors are paint grade.
Thanks for your suggestions.
Cool
Id use a glue size on the MDF panels then sand and prime. I used to use shellac to seal up the "end grain" in MDF but found glue sizing to work better and seal up the edges and provide a better base for the primer and paint. Ive used Titebonds gluesizing with great results.
Glueing panels to your R&S isnt adviseable, MDF still swells and shrinks.
Sherwin-Williams ProClassic 100% Acrylic paint, and ProClassic primer. Dries hard as oil, with no odor. Brush or spray. Thin both 20% to spray. 'Nuff said...
Cool,
I agree with Wmp. Gluesize or a sandable sealer, followed by sanding. I usually do it twice. Use an oil primer so it wont loosen the fibers (latex will), spray all the paint, no brushes. This leaves my doors looking perfect. Unfortunately MDF does still expand and contract a little and this can cause the paint to crack at the panel/ frame line. Latex remains more flexable than oil so that is what I try to use as the top coat, if I can. With Latex I have not yet had any cracks develop in the last 3 years. After about 10 years though latex also begins to get brittle. In order to look good latex MUST be sprayed, and it is a lot harder to spray than oils, so it is hard to find a good painter that can handle it.
Thanks for your suggestions. I have printed them, and will suggest that my sister-in-law pass them along to the person who will do the finish work.
Is this a great forum or what!!
