i just finished building the bow front hall table in fww204. I built it out of some mahogany that was given to me. Iam going to put some holly and ebony narrow band inlays in from the table top edge approx. 11/2″
my question is how can i bring the banding flush to the table top ,stain,pore fill and top coat with lacquer without getting stain on the banding
i thought about routing my groove then staining, and sealing with dewaxed shellac ,glueing in my banding, carefully hand sanding my banding flush,sealing again with dewaxed shellac then pore fill then seal then finally top coat
i could really use some help with what procedure would work
also i understand that sanding dust from the the ebony could stain the holly so mabey planing flush with a block plane would be an option but i would have to avoid planing into the stained mahogany
On a small piece I have sanded everything flush than put shellac on the inlay and then finished the rest of the board. Filler, stain and then shellac.
Im darn gla you asked that question cause I cant for the life of me figure out how to do it with the banding already in there! I can tell you shellac as a sealer over inlay does nothing! Especially if filler is tinted. I ended up making a small scraper to scrape all of the inlay!
Chris
Maybe Mr. Millard will step in here and let us know the secret!
Edited 5/25/2009 9:03 pm ET by hdgis1
I have been thinking about this same issue for a walnut table I am working on with stringing, banding and inlay of several different species. I would really like to dye the walnut with a water based dye to even out the color a little and I was planning on sealing the inlays, etc. with shellac. Hdgis1, could you tell us what exactly you tried and where it failed?Thanks much.
Chris
It's very hard to sand inlay flush without sanding through stain, very hard. One approach is to color the mahogany with a chemical stain--potassium chromate is one, albeit a poisonous one--that would then have almost no effect on coloring the holy. That means you can sand, scrape, or plane your inlay flush before you do the coloring. Then you can use a light colored shellac as your pore filler, applying several coats, sanding back to just short of cut through, and then repeating. (The chemical stain also gives a bit deeper penetration than oil based stains, thus giving you a little margin while sanding back the shellac. Shellac would also make a good general finish one you have filled pores.
Working with chemical stains is a bit tricky--you will have to make careful practice pieces with scrap from the same wood in order to get the concentration right and to be sure that some boards don't react too differently to the treatment.
The following link has some information on working with mahogany and inlays (see the May 19, 2008 entry).
http://www.rlmillard.typepad.com
I have not had any problems with ebony discoloring holly, when I scrape it flush and only sand with 320 grit paper in a random orbit sander, hooked up to a shop vac.
Rob Millard
Nicko
I have had good success bringing the inlay down using a small block plane or a sharp chisel (in tricky areas where inlays intersect) then finishing it to flush with a card scraper. I find that going right to a card scraper can be a little too traumatic and can cause damage (I hate it when you pull out a hunk of inlay!) With a good sharp plane set to a very fine shaving you can work that inlay down a little at a time - taking your time - until the curl that comes from it has just the slightest trace of the adjacent wood at the high points. At this point, when you move to a card scraper, everything is on around the same plane so the scraper can't get too much purchase in any one piece for it to pull out in a hunk.
As for the finish. Tough one there. I am generally not using stains when I do this kind of work. You can obviously stain the mahogany first, then inlay. However, at some point you will have to scrape flush and will probably scrape the mahogany enough to impact the stain. I suppose you could then go back and carefully restain the areas that got shaved. I think the retouching would be far greater if you sanded. Just my opinion.
The project I'm on now is mahogany with mahogany, crotch mahogany, holly and rosewood veneers. I'm going to use some kind of combination of BLO (or not) and shellac to get the desired result. I made some sample boards from the primary solid mahogany and inlaid pieces of the other woods in it. I then kerf the sample boards into 3 sections each for testing. Different types of shellac, from blond to garnet and a blend over bare and BLO prepped samples will give me all the variations to view before I experiment on the piece itself. If I think I need to, after the samples are finished, I may have to make more samples where I tint some shellac coats with dye to get the effect I want. You will see in the photo, how the blond shellac lets the white holly come through, where the garnet obscures the white. The blend in the middle is a compromise. The sample board above it has been prepped with BLO but has not received the shades of shellac yet. I'm hoping that the BLO board with the blond shellac will show more richness in the darker tones, but still let the holly pop. I'll find out tonight!
I'm not trying to talk you out of stain - OK I am - but I want you to think about why you would want to stain mahogany on a fine piece like that. I'm sure there are other schools of thought. I just think that when you are working in fine materials, stain lessens the end result.
I'm trying to attach some photos, but as usual I can only get them inserted in a huge format, so I've attached all of them on one .pdf file.
Practice your inlay and finishing techniques on scrap. I'm sure you will work it out!
Frank
frank
thanks for the encouragement and taking the time to answer my post also thanks for "talking me out of using stain"
the stain is what was throwing a wrench into the process. the reason i was going to use stain is that i was on target coatings web site and the owner jeff weiss shown a sample of mahogany with red mahogany stain. it looked like a nice red color i was looking for.
i will try some sample peices and see what i come up with
if you want to. go to target coating web site and click on forums then click on stickys and look at the sample
thanks again
nicko
