Can anyone provide input regarding their opinions of finish to be used on maple that will be relatively durable yet add depth and enhance the wood ? I’m interested in a deep luster finish.
I can’t spray but other then that I’m open to techniques.
I’ve tried General Finishes oil and water based poly’s but I don’t seem to be getting the depth and luster that I’d like.
Due to variations in maple boards on this cabinet combined with some baltic birch side panels, I’ve discovered via test boards that any stain (even when surface prep / conditioner applied) results in very distinct variations in the colors of the piece as well as some blotching.
Although I wanted to apply a stain then finish to a luster, I’ve discovered from testing that I’ll have to leave the maple and baltic birch it’s natural color and try to dress it up and give it depth the best I can with only a finish.
I’m a finishing rookie, so I’m really looking forward to thoughts, comments and help from some of you guru’s.
Thanks in advance.
Greg
Part of the problem may stem from using polurethane varnishes or waterborne finishes. The slight haziness of the poly keeps the film from giving that shine from the inside that you sound like you are looking for.
As far as coloration, your best bet would be to use a dye. Dyes tend to pull colors together and also blotch less than pigmented stains.
Probably the best finish for getting the look you describe would be shellac. It can give a very nice glow without being a really thick coating. It also rubs out very well, so you can build the finish, and then take pains in finishing the finish to what ever gloss you want.
Here's what I have done in the past: Rub in a coat of Danish oil (e.g. Watco clear). I usually apply this with 400 grit sandpaper instead of a rag or brush to give the piece a nice, burnished finish. Wipe it down and let it dry 3 or 4 days. Re-sand lightly if needed. Then apply wipe-on poly.
The oil brings out the grain, the poly protects. Make sure the oil is completely dry before adding the poly.
Mike Hennessy
Pittsburgh, PA
French Polish.
Perhaps a bit difficult, certainly time-consuming.
But absolutely worth it. The finest factory-applied finishes are a poor second place.
Lots of articles have been written -- probably a bunch of posts here -- try the search function.
Politics is the antithesis of problem solving.
Suggesting French Polish to someone with no experience,is like telling someone with a learners permit to drive a porshe at 200 mph.
French Polish is the hardest of all finishes to apply,and the least durable most fragile.
I stopped french polishing 20 years ago.
I can duplicate it,in a tenth of the time and add durability.
How?
Hey Everyone,
I apologize for the delay on my posts. I was out of town and did not have internet access.
That being said, I wanted to thank everyone for their input / help. Back to the drawing board and we'll just see what happens.
Greg
