I’m about to finish a large mirror frame made of hard maple with a gel stain. While researching what finish to use I thought that i read that i should sand to 120 grit and no more on hard maple. I’ve done so, and although the surface is smooth, there still appears to be some fine scratches. Can anyone confirm what grit I should stop sanding hard maple at. I appreciate the help.
I would suggest you finished sanding with 180 grit. Those scratches you see from the 120 will be magnified after you stain if they are left behind.
Peter
Thanks Peter. I'm sure you can tell I've had limited experience with finishing. Up until now it's been brush on Minwax and HVLP spraying poly. I followed manufacturers instructions and sanded to 150. Used a minwax wood conditioner and stained with General Finishes gel stain. I'm on the second coat of my sample piece and there is still significant blotchiness. I've read your posts and I see you are a big fan of dyes. Would this be an option for my project and could you recommend any literature on the subject (or give me any tips). Is there a better method for a relative novice of finishing. I've read that gel stains are fool proof. What does that make me. I'm looking for rich, deep, reddish brown mahogany color. Can you also recommend a filler to use on small gaps in the miters. Should filler be applied before or after staining? It's a large hard maple mirror frame (66" x 36") to be hung in my living room and a crappy finish will ruin all my hard work. Thank you for any insight.Edited 12/17/2008 10:58 pm ET by sflood75Edited 12/17/2008 11:08 pm ET by sflood75
Edited 12/18/2008 10:59 am ET by sflood75
