In the current issue an article on building a corner table
mentions the use of figure 8 fastenes to attach the top
and allowing for wood movement. How do they work? Where can I
purchase them?
Ken,
A figure 8 fastner is basically a siamese twin washer - two washers joined at their sides. You can screw down into the rail and up into the top by positioning them so that one of the rings hangs off the rail.
The upper-right photo on page 54 shows them in all their glory.
As for sources, I'd have to hunt a round a bit but I'll let you know if I come across any, but I'm sure someone will post a source before I find one.
Shop made solutions are easy as well. I generally make a slot mortise in the rails and make blocks that have a little wing that fits in the slot and screw the block to the top.
A napkin sketch of this technique is below.
Best,
Seth
*Rockler I think has them.
*John: Thanks much. I have always made my own wood connectorsas yourself but my current project would be better servedwith the figure eights. However, I still don't see how theyallow wood movement. Unless they pivot or somehow expand, howdo they fulfill their promiseken
*woodcraft.com or your local store - they carry themRobert
*Ken,The swivel on the screws. If you have them at a slight angle then expansion will just move them as needed.Best,Seth
