After the review in FWW I’m thinking of buying a Festool sander. My old PC has died leaving me with a couple boxes of sanding disks that will not be usefull on the Festool. Does anyone know if there is a way I can use the old disks, maybe an adapter or an easy way to change the hole pattern. Thanks in advance.
Dennis
You can use the old discs on the new sander. The dust collection will not be as good as with the correct discs, but they will still sand wood. Remember when sanders didn't have dust collection?
Edited 2/26/2009 10:43 am ET by Jamie_Buxton
If you want to punch new holes, then I suggest you make a plywood or MDF pattern, a copy of the Festool disks, where the holes are the OD of a suitable leather-punch. You can then put the ply disk on your old PC disk and pop the punch through the drilled holes.
S
Woodworking DVDs and jigs from http://www.workshopessentials.com
Dennis,
I have the 6" and the 5" Festool sanders and have never regretted getting them for a moment. I am not one of those guys that thinks that Festool is the last word in tools,but I like their sanders and their plunge saw system. The key to their dust control is that center hole. If you punched that out and aligned a few of the other 8 holes, assuming they are the same distance from the center, you should be OK. Festool prices on their sandpaper are not bad, I don't think Klingspor can even compete with their prices. Klingspor is the only place I have seen paper that fit their machines, but I am sure there are others.
One thing to remember with Festool sanding disks is that there are two types.The light grey ones are called Brilliant and they are designed for sanding finishes (even though they go down to P80). The Rubin ones are copper-coloured and are designed for wood.I don't know about in the US, but in the UK most stockists have the Brilliant but not the Rubin, which is a pain.Of course, I didn't find this out until I'd bought boxes of 50 of several different grits, all Brilliant.....Festool Fact #1 - Did you know that Festool make their own Velcro for pads, as regular Velcro is too loose?Festool Fact #2 - Did you know that the reason that there is no Festool Biscuit Jointer is that they reckon they can't significantly improve on the Lamello, so what's the point of being a Me-Too?Cheers
SteveSpace is more valuable than the junk that occupies it.
Edited 2/26/2009 12:38 pm by Steve Maskery
I agree with the statement about Festool sanding disks. Buying the sander is a big financial outlay (though I don't think you will regret it one bit). But thier sandpaper is a bargain. The disks are, in my opinion, much higher quality that what you would pick up in a box store, and cheaper too. And as was mentioned you can get actaully like 5 different types of disks for everything from bare wood, to finishes, to solid surface, to grease removal (I don't know about that one though personally).
Anyway, I say all that to say this, when you buy your sander, go ahead and buy an assortment of papers, then use those old disks for handsanding or something.
Actually I definately understand about being frugal, but I would hate for your first experience with a newly purchased expensive tool to be less than what it should be due to having to rig up the consumables.
Good luck
