In FW 176 Ernie Conover reviewed Zinsser’s new French polish in a can and said he uses felted wool as padding material. Does anyone know where I can buy felted wool?
Philip,
Most any fabric shop will have felt by the yard, whether it is wool is another question. How 'bout one of dad's old fedora hats? Try at a thrift shop.
Cheers,
I've used a piece from old snowmobile boot liners for a conforming sanding block. With French polishing, you want to use pure wool as the wick in the mouse. The liners, today, are often polypropylene or a blend. A piece from an old wool sock or sweater wrapped inside a couple layers of old white cotton T-shirt is a favorite. The wool will hold but not absorb the shellac. With traditional French polishing, you don't want very much shellac weeping through. Just a few drops on the wool is usually enough. A drop of olive oil on the cotton is also a traditional method. Touching down and lifting off the work is a bit tricky at first, you use a circular motion with a feather touch. It's a lot of work for what I consider a delicate finish. Make sure you practice on a scrap first.
It's pretty easy to "accidentally" make felted wool. Get some wool fleece from a spinners' supply oufit. If you wash it "too much", it turns into felted wool.
I know this because LOML is into spinning.
If you can't find wool use some cotton wadding. It is easier to find and works the same.
J.P.
My wife and I own a Knit Shop and felting is a big thing these days. It's really a simple process: Wash hot, rinse cold, very little soap. We recommend using a bag like a pillow case, whether felting knitted work or fleece (roving).
Pure, untreated, unbleached wool is best.
DonI'm not the man I used to be, but then I never was!
I'll give it a try. Does it work to just handwash? Or do you need to machine wash?J.P.http://www.jpkfinefurniture.com
Hand washing will work. Do it as hot as you can stand it and give it a lot of agitation, followed by cold rinse and lay it out to dry. You won't believe your eyes!
Thanks for the tip!J.P.http://www.jpkfinefurniture.com
