Hi dgreen,
I mention your name in this post , hopping you are still there at your shop at this time.
I used to push & pull the router machine (hand held) when making simple groove and simple edge shaping. I do not notice any different results. Am I doing the wrong way? However I never try to feed in the work-piece to & fro when using router table. Is it dangerous by doing so ?
Masrol
Hi Masrol
Going the wrong way (climb cutting) can be dangerous on the router table, there's a good chance it will grab the wood and shoot it across the shop leaving no wood between the cutter and your fingers. Climb cutting on the shaper I've had it shoot the wood out even when using a power feeder and stiff featherboards. Happened often enough and violently enough that I broke down and bought a left hand cutter for that operation.
Hi dgreen,
Thank you very much. I shall never try to do that .
If ever you can see me on your computer monitor screen, you would see my smiling face. First because I still have someone to communicate to at this hour, and secondly my guess is right that you are still at your shop.
Bye and thanks again.
Masrol
Cutting mouldings on the router can be done safely. Figure out which way to push the stock. Use feather boards and use push sticks or blocks to keep your hands out of the way. I also have a guard mounted on my fence over the blade.Nothing screws up the finish as much as blood and bits of bone .
Frank
I did'nt think his question was whether it could be done on the table but rather if feed direction mattered.
Dear dgreen,
I post the question whether it is possible to feed the work-piece to and fro on the router table because I find it difficult to avoid tear out esp. when cutting profile on the end grain (across the wood grain). I used to back the work-piece with scrap to solve that problem and there was occasion where I ran out of scrap.
When come to cutting rail & stiles, as advised by technical instruction - I do that profiling on the router table only. If, and only if, the router machine can be set to reverse rotation, possibly we can avoid tear out by cutting the profile half-way through and feed the work-piece in the reversed direction. It's just my presumption. I could be wrong.
Masrol
Edited 5/4/2006 4:15 am by Masrol
If you can get some pieces of UHMW plastic it makes great backup blocks and lasts nearly forever. Lee Valley sells some assortments of UHMW scrap that I have found very useful for that purpose, pretty reasonably priced too.
Wow dgreen...! You can stay up till 3:11PM ?
Anyway, won't the knife cut the UHMW too ?
Masrol
Masrol,
On a table mounted router, you feed from right to left over 99.5% of the time. THe other stuff is higher- skill stuff where you may be running a particular trench.
It is dangerous to feed material from the Left hand side into the router bit.
This diagram may help you when you are using a hand-held router.http://forums.taunton.com/fw-knots/messages?msg=9488.5
Cheers,
eddie
Hi Eddie,
Thanks for your reply and the link attached.
Since you are from Australia, are you staying in Australia ? Is it easy to get woodworking stuffs (machines, tools & materials) in Australia ?. What about on-line shops ? I seldom come across Australia based on-line woodworking retailers. The shipping cost (from Australia to Malaysia) could be cheaper as compared to (from USA to Malaysia).
Masrol
HI Masrol,
There's a few you could try:
http://www.carbatec.com.au
http://www.mik.com.au
http://www.thewoodworks.com.au
http://www.timbecon.com.au
Cheers,
eddie
Thank you Eddie for the info.
I should make a try.
Masrol
The knife does cut the UHMW and leaves the profile on it, just keep using the same piece. As long as it supports the profile the backer will prevent blowout.3:00 AM PST
Thanks.
Masrol
"...because I find it difficult to avoid tear out esp. when cutting profile on the end grain (across the wood grain)." This may have been mentioned earlier, but it bears repeating: rout your end grain first, then do the other two edges. the subsequent passes should clean up any tear-out at the ends of the end-grain cuts.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Thank you Jamie.
Masrol
