Hey all, wondering about glue for an exterior application (Gate with a lot of joinery)
that has a long open time. Some kind of epoxy I’m thinking but looking for any
and all options. Cedar and Mahogany are the woods being used. Thanks so much.
Look at West Systems epoxies. You can get any open time you need.
David Ring
Here are some longer open time exterior rated adhesives.
Titebond III -- 20 minutes
Urea Resorcinal -- 20-30 minutes
Epoxy, 2 part, slow set -- 30 - 90 minutes depending on the catalyst.
Additional info:
Titebond III -- not my first choice if I need more than 5 to 10 minutes. I always feel rushed. you can slow the set time by refrigerating your glue - just be sure to shake it up before using it.
Urea (plastic-resin glue) -- you can buy it pre-mixed or in powder form. It works great, its cheap and will hold up outdoors. Just be sure to keep it warm while the glue sets. Depending on your location - it may be hard to find.
Epoxy, 2 part, slow set -- 30 - 90 minutes depending on the catalyst. I love this stuff. You can eat lunch, literally, in the middle of your glue-up. Unfortunately, it is the most expensive option and you need a warm shop for the curing period (12 to 24 hours).
Urea Formaldehyde (Plastic Resin and others) is rated as meeting the ANSI Type II specification for "water resistant" adhesive, not "water proof".Urea Recorsinol is rated as meeting ANSI Type I specifications for "waterproof" adhesive.TiteBond III is an ANSI Type I adhesive "waterproof" as are most two part, slow set epoxies.This is not to say that a Type II adhesive would not meet the needs. Type II adhesives are tested to maintain adhesion from multiple wetting and drying cycles and are generally perfectly OK outdoors unless used in a continuously totally submerged application.Howie.........
I use epoxy for this. Here is a source for about half the price of the one that David recommended.
Please click on your name, and fill out your profile, at least your location. If you are on one coast, and I could give you a source next door, or the other side of the world, which would you rather have offered?
http://www.fgci.com/
Keith thanks for the reply. I'm in Oregon. Do you mean the
West Systems epoxy? Pretty sure I can get that locally.
As Howard posted.. Urea Resorcinal
I made a Cabin Crusier from plans (maybe Popular Mechanics?) way back in the 1960's using that sort of red gule at the time. I no longer own, it but it still floats!
Gorilla glue has a long open time,if I recall at least one hour.
mike
Gorilla Glue has an open time of 10 - 15 minutes.
http://tinyurl.com/5np6qm
Siskiyou - Something worth keeping in mind is that all glues in exterior woodwork will fail, some slowly, some very rapidly. The simple reason is that in outdoor applications, the wood will expand/contract quite a bit with humidity changes, and if the construction is cross-grain, such as mortise and tenons, the differential dimensional changes will split the glue off of the wood.
It's for this reason that NBC (national building code) prohibits glue-only joints in any structural application - they must all have fasteners. In the case of your gate, you can draw-bore and pin the M&T joints, and they will not fail until the wood rots, with or without glue.
