Dear Gary
I just read the article
Extension Tables
Their design and construction
Dear Gary
Extension Tables
by Jeremiah de Rham
I have a wooden dining table with 2 pedestal legs which is far too big for my current dining room. I am reluctant to get rid of the table and wondered if the center third of the table could be cut to shorten the table and a sliding mechanism as described in the article or any other mechanism used to extend the table and use the leaf that is removed to extend the table.
Thank you for your help
Fred
Hi Fred,
How is the top held on? This will determine whether you'll be able to cut a section out of it. You need some kind of restraint to keep the top flat. Usually, in an extension table, this means aprons. So the grain will run the short direction across the table with the aprons holding it down tight and flat.
If you cut a section out of your current top, you might not have any way of keeping it flat while still allowing for cross grain movement.
Check that out before grabbing your saw. Good luck.
Gary Rogowski
Director
The Northwest Woodworking Studio
thanks for your advice. will check with someone who knows more than i do!
Fred
