I have a mohogany slab about forty inches in diameter that I am making into a table top. I’m concerned that the end grain nature of it will pose some finishing challenges. Any ideas on the best strategy to seal, fill and finish? Thanks.
Start Your Free Trial
Is it cured so it won't crack?
It is about three inches thick and was brought from the Congo by my Dad about fifty years ago. It is solid and only has some very small surface cracks in it. I think it is pretty stable.
Steve
Given your description, I'm quite sure that it will never make a good table top -- it will just be ugly and a big problem.Instead of going to the trouble of making that table, I think you should just ship that slab to me. I'll "dispose" of it in good order.<grin>
I won't be laughing at the lies when I'm gone,
And I can't question how or when or why when I'm gone;
I can't live proud enough to die when I'm gone,
So I guess I'll have to do it while I'm here. (Phil Ochs)
More seriously......What Steve said about a few coats of shellac as a starter, is great advice. Be careful to try to get every surface covered, so that moisture and movement are as even as possible over the years.
I'm very cautiously optimistic that I can render it useful somehow. I wonder also if it will be worth filling the grain before finishing.
Thanks for the reply.
Steve
Just a thought here, because I've never filled endgrain.Assuming you plane, scrape, and sand properly, The end grain of mahogany won't be all that much different-looking than face grain.I'd guess that if you filled the endgrain, it wouldn't be much different at all (again, still guessing here).And so the question becomes -- do you want this slab to look like an endgrain slab, or do you want it to look like a round piece of mahogany?
I'm envisioning a nice bistro table with a high gloss finish and routed edge that highlights the age rings of the slab (about 150 or more). My dad brought this home decades ago and it has sat around forever. He is now 88 and I would like to do something with it that he would appreciate.
Then have at it, and have fun. I'd plane/sand/scrape to get it as close to dead flat as possible. then fill the grain and re-sand.Then, depending on your finishing skills or equipment -- maybe a french polish, or some well-rubbed-out shellac or lacquer.
I would like to see a pic. Please before and after
I'll post some pics as the process progresses. I'll get the raw slab posted in the next week or so.
http:http://www.preservation-solutions.com/faq-pentacryl.php//www.preservation-solutions.com/faq-pentacryl.php
Pentacryl!
Short of somethink like Rick's Pentacryl suggestion, it is extremely difficult for a crosscut slab not to split as it cures. It is often suggested to make a radial cut from edge to center to direct the splitting.
After dealing with the basic splitting issue, I would generally slow (you can't really stop it) moisture transfer with a number of coats of shellac, top and bottom. Then, if you want, you can put a coat or two of a more durable top coat--such as an oil based non-polyurethane varnish.
