I have just finished building a new table for our breakfast area. The base will be painted and the top, which is made out of maple, I would like to finish with an amber colored stain and satin top coat.
Applying finishes is typically a challange for me as I usually have problems with the finial top coats being ruined with lint and dust. As I do not have a spray booth I have tried the various wipe on finishes, application by brush or spray cans, with varying degreas of success.
How does one achieve a nice that nice smooth satin finish unblemished by lint and dust? I do understand the methods of rubbing out a finish however, large particles of dust or lint do not rub out cleanly. Thanks.
Bob
You have to get rid of the dust in your finishing area. Many folks finish up their sanding and go straight to applying a finish. Of course, this will always be problematic.
Here is what I do for the final coat. First I sand on my downdraft sanding table. Then I turn on my air cleaner, vacuum off the project and vacuum the all the wall, floor and other surfaces I can reach. Then I go out of the shop and leave the air cleaner running. A couple of hours later, after changing my clothes, I go back and wipe the project down with mineral spirits and without stirring up any dust, I begin to finish. Then get out of the shop until the project is tack free.
I know it sounds extreme but if you don't follow some procedure like this, you will always have dust in the air which will settle on the finish.
As a professional finisher and coatings chemist with two patents in polymer science, let me assure you of this fact: Blemishes in a final topcoat hardly have anything to do with fine sanding dust. I routinely would sand IN MY SPRAY BOOTH without blemishes.
I've spent many hours picking out the "nerds" as we call them, out of the final clear topcoat (after air hosing and tacking the surface) and discovered that about 90% of all the nerds that disrupted the surface tension of an otherwise glass-smooth top film are actually pcs of lint - tiny short bent hairs from the fabric of clothes. Remember that the wet mil film of many topcoats can be as much as 15 mils, which is more than enough to absorb the average sanding dust particle of 50 microns (two mils across). This means that its only the stuff that sticks up higher that ruins a finish. These pcs that stick up higher are NOT going to be floating in the air very long, (large clustered duct particles), hence no need to worry about the sanding dust in the air, just need to worry about the lint that might be floating instead, which is combatted a different way.
When I realized that lint was the major culprit, I began protocols that limited the dust in the air to graet success like removing my shirt, blowing all dust off my arms and upper body, and spraying the piece with my back to the spray booth, so that the air flow pulled clean air over the piece, not air that went past any clothes or me.
To translate this into your situation, Bob, I would:
You will ALWAYS have dust nerds dried into the finish no matter how perfect your dust control is (unless spraying top upside down - works pretty well), so learn to wet sand 1000 grit, then buff with automotive rubbing compound and final glaze.
One trick I love is slicing off the nerd flush with the surface with a new razor, then cross-scraping with the razor, just before wet sanding. With practice, you'd never know you took a razor to the surface.
- JB
"The furniture designer is an architect." - Maurice DuFrenes (French Art Deco furniture designer, contemporary of Ruhlmann)
http://www.pbase.com/dr_dichro http://www.johnblazydesigns.com
Thanks for the detailed response. I tend to agree that most of the rough spots seem to be due to lint or hair (from the cat) that has come off of my clothing and settled onto the wet surface. Although I have done a thorough cleaning of my shop prior to finishing I never gave much thought to what my clothing may be carrying. I will try rubbing out the surface to see how much of this I can remove.
Bob
Put on the last coat upside down. Helps slightly. Run a humidifier. Dust seems to be actually attracted to the wet finish by electrostatic charge. Some materials and finishes attract more dust than others. Finishing in very dry conditions does not help. The old way was to hang a curtain around your work and wet the curtain. I suspect this helped more from the humidity than by actually removing dust from the air.
Bob,
If your rubbing out process does not remove the defects in the surface, the info in the article at this link has the solution - Rubbing Out a Finish.
The article recommends using a sanding block and sandpaper to remove surface defects and level the finish but on flat surfaces I like to use Abralon pads on a random orbit sander. As long as the finish is thick enough to cut back level, the Abralon does a great job and is quick and easy. For a satin sheen, grey scotchbrite on a square palm sander is another labor reducer.
Paul
Rkelm...lots of good suggestion here. I can only add that you might try a finish that dries fast. I have had very good luck with Quick 15 fast dry alkyd varnish made by Zinsser and sold at Sherwin-Williams stores. It is tack free in 15 minutes.
Art
I suggest you use a wipe on varnish. It will dry quickly so that dust will not stick in it.
As others have said - use a finish that you can repair.
