Is it possible ( if so, how) to have a dust collection system for a lathe? Full size lathe. If so, what do you position where?
Alan – planesaw
Alan – planesaw
Planesaw:
The short answer is yes. Just do an internet search on lathe dust collection to see what is available. Here is a link to a cheap lathe dust port by Rockler. http://www.rockler.com/product.cfm?page=10578. I don't know if it is any good, but the price is right.
gdblake
Thanks gd-
I have seen the item in your link, however, I am hoping for advice from someone who has used a lathe extensively and knows what does and what does not work regarding dust collection around lathes.
Alan - planesaw
I set up mine with one of those large "hood" type catchers and set it in a slot (with a stretch of wood) so I can slide it to the area of the lathe where I'm using it.
Denny
Blew-
Placement at the back of the lathe? The side opposite you?
Alan
Yeah. Behind the lathe I set up a wood strip with a slot in it, in which just nests the bottom edge of the collection hood. I can slide it left or right to the area in which I'm working the lathe. (Hood is hooked up to about 6' of flexible hose). Not a perfect solution, but best I could come up with. But I usually don't use it when making my major shape forming because running that durned dust collector for blocks of time on end get on my nerves. I use it primarily when I'm sanding on the lathe. As for the preliminary chip cutting sessions, I just let it drop then blow it out or sweep it up.
Denny
Thanks Denny. I like the idea of the slot and being able to slide it left or right.
I was hoping for some magical solution that sucks away 90% of the chips, but that would have to be chest high between me and the lathe apparently.
Maybe the big gulp, as I have heard it called, elminates some of the finer dust. I do wear a dust mask and hearing protectors whenever I have the dust collector on. At 62 I want to protect all the hearing I have.
Thanks for your info.
Alan
The only way I know to do that would be to build a custom hood (1/4" ply maybe) with a duct shute that set itself all the way across the back of the lathe. Finish it with some glossy poly to promote sliding of the waste materials. Actually, now that I think about it, that wouldn't be so hard to do.
A lathe is something I use only on rare occasions so it's not a biggie for me. Joiners, planers and sanders are what produce the most mess for me. Also the band saw but dust collection on my bandsaw is piss poor at best.
Denny
Sounds like we could be twins on each point you made.
Alan
