My drill press is a floor mounted Delta X5 – variable speed. Suddenly on startup – it makes a terrible noise for a second or two as it comes up to speed. Once up to speed, it seems to run as smoothly and quietly as it ever did. Simultaneous with the noise, there is a momentary lag in the chuck starting to spin. The taper seems to be well seated, and I can’t see anything wrong with the belts. I’m not certain of this, but I can’t detect the lag when watching the belts. Any help will be appreciated.
What kind of sound is it?
A hum or buzz indicates a motor or electrical problem.
A squeal hints at a belt slipping.
Rattling or metal-to-metal grinding means a bigger problem.
I won't be laughing at the lies when I'm gone,
And I can't question how or when or why when I'm gone;
I can't live proud enough to die when I'm gone,
So I guess I'll have to do it while I'm here. (Phil Ochs)
Sorry I didn't describe the problem better. The comments about the type and location of the noise prompted me to explore a little further. Definitely not a buzz or hum - nor a squeal or grinding. More like a hand-truck running through a pile of metal ductwork. I have a hearing problem, but on further review I think it's coming from the belt area. After allowing it to start and run smoothly, I tried shifting into the high-speed range, and the noise returned with a vengeance. That makes me wonder if it could relate to the speed control mechanism.
It could be a bearing.
Perhaps a bearing. Would it not be unusual for a bearing to cease it's noise-making after reaching full speed?
"Would it not be unusual for a bearing to cease its noise after reaching full speed."
Not so unusual. If it is a flat ball in a ball bearing, I think they might turn on their side and cease its noise. You might also look for a loose pulley, shaft, bearing.....
Remove the belt,no noise no motor problem. Check the pulleys ,the keys and setscrews, and the belt. The noise you describe does not sound like a bearing. Usually a bad bearing makes the spindle harder to turn than usual. The sound you describe makes me think pulley and belt .
mike
Thanks Mike - Will check that out tomorrow.
You didn't say where the noise was coming from. My RAS made a noise and hesitated like that. The problem was corrected by replacing a bad condenser in the motor. Of course, with a RAS about the only thing that could cause a noise at startup is the motor.
