Can anyone direct me to a Fine woodworking article on how to hang a internal door
regards Charnwood
regards Charnwood
I think you mean "inset" door
https://www.finewoodworking.com/.../SkillsAndTechniquesPDF.aspx?id=24132
link
Let's try that again . . .
https://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=24132
door hanging
are you looking for info on hanging a interior pssage door ?
i can help you with that !
Yes I am looking to hang an internal passage (that is a door to a bedroom)
regards Charnwood
hanging an interior door
In that case, you'll need a taller interior tree from which to hang the door, not to mention a high ceiling. ;-)
The finish-carpentry folks at Breaktime (http://forums.finehomebuilding.com/) could likely provide more detailed info. But, it seems to me that the major issues are:
1. making sure the door fits in the available space of the door jam,
2. determing whether a new jam needs to be installed,
3. matching the hinge-mortise placement on the jam to the hinge placement on the door,
4. shimming the door for proper floor clearance while marking the jam, and
5. keeping things plumb during the process.
But, I might be unhinged, so to speak. ;-)
Try Fine Homebuilding
There are a lot of tricks to make this type of work go easier. You want to go over to the Fine Homebuilding site for this however. They have published several articles on the subject.
