Hi all
After ths discussion on disposal of thinner, I got to thinking (yeah, I know, dangerous) about the water based stuff.
I don’t have running water in my shop, so I bring brushes into house for cleaning.
But I have a septic tank, so is this bad for it.
Also, could I wash brushes in water in the shop (like thinner) and let it settle out the same way?
I often just pour water after using it for cleaning on the ground. How bad is that?
Any thoughts on this?
Good question. I have never heard or read anything about ill effects coming from washing water based products in the sink, and letting it all run down the drain.
Will be interesting to see what more knowledgeable folks around here have to say.
Nick's coming home from Oregon tonight, I'll run it by him. A MSDS for one of the water-based products should give him the info he needs. We're on a septic tank too, so I'll be interested in the info.
FG
I'll be leaving for 4 days early Sat morning.
So, if you post early, I'll see it late Friday nite.
If not. keep it alive till tuesday nite.
Hi Jeff, just got an email from my sweetie, and he's having to stay in OR tonight, so I might not post for a couple of days. Hope you trip is for fun purposes.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Visiting my parents.
Every 2 months.
OK
I'm back.
Any new info?
Hi, Yep! Busy weekend....anyway....
You're definitely right about not disposing in septic tank.
Best options are to let evaporate or, if you have access to a drain that goes to a municipal treatment plant, pour it there. (For instance, we are on septic at home, but I can rinse brushes in the bathroom in my store downtown and that water goes to a municipal sewer.) Obviously, do not pour down street drains.
Pouring on ground is OK if it's not real large quantities. Spread it around. Stay away from any place that would run down to a stream or lake (if you're lucky enough to have one in your backyard).
Again (for others who might read this post) do not let run into street drains. This is true for just about everything, including washing your car, which should be done on the lawn, not in the driveway (my salmon-saving instincts are raging!)
I found the MSDS for Minwax Polycrilic at this site:http://www.easternct.edu/depts/env_saf/msdspaint.html
Thanks FG
Guess it's time to go to plan B.
Jeff, I just re-read your original post and noticed this sentence:
"Also, could I wash brushes in water in the shop (like thinner) and let it settle out the same way?"
They are two difference situations. With the thinner, what you're doing is letting solids settle to the bottom and pouring off the now-clear thinner to use again. With the wash-water from your water-based cleanup, the whole solution is going to have substances, like the various propanols and ethylene glycol, in it. Still, in relatively small quantities (a gallon here or there of wash-water) pouring it around on the ground as described won't hurt.
Then there's always cheap kitty litter, LOL (non-clumping of course).
FG
I don't have running water (yet) in the shop.
I carry a 5 gallon container in and set it on a shelf (It has a built in spigot).
My sink has a drain pipe to the outdoors (no way to get to the septic system).
I have a second sink that drains to a bucket for misc stuff I don't want to just dump on the ground.
Not the best system, but I suppose it could be worse.
And yes, every now and then I pour water from a brush onto the ground.
I keep some kitty litter in the shop for some uses.
My cat likes the clumping style (so do my dogs, heh heh.)
"Not the best system, but I suppose it could be worse." No kidding! Sounds good to me.
"(so do my dogs, heh heh.)" I won't burden you with info on my old (gone) coonhound's relationship with the cat box, LOL!
"My cat likes the clumping style" So do mine, I guess. They've never complained anyway.
Cheers!Jamieforestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
FG
Forgot to mention, I have pretty much always used solvent based finishes for the ease of disposal and clean-up.
Also, I find it easier to spray in my old equipment.
With the new water based clearcoats, letting them run into drain basins is not recommended.
It's best to let them evaporate,then dispose of the material as ordinary trash, unless you have a hazardous waste p/u or dropoff which is best of all.
Jackplane
Hazardous waste pick-up is what I bring to the twice a year pick-up day.
Needless to say, things tend to accumulate for then.
I'm not surprised that the new clearcoats are not very friendly.
JP, could (would) you give some brand name examples?forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
You mean examples of clearcoat finishes?
Well, many manufacturers make water-based polyurethanes,even calling them lacquer when they're not. Benjamin Moore's are called Mooregard, I think. As I mentioned in a previous thread, the product label stated, "May cause harm to reproductive organs". Many folks have the impression that these water based finshes are safer than solvent based ones, but they're not.
Seems like the Minwax Polycrylic I used as an example above is the type of finish you're referring to. The main concern when handling these finishes is to avoid prolonged skin exposure. This is probably where alot of people go wrong, thinking because it's "water based" it's OK to work without gloves.
With regard to disposal of washwater, obviously, there's not time to find the MSDS's of all possible waterbased finishes here. However, reading the one for Polycrylic, we (hubby and I) didn't see anything that would cause concern for disposing of reasonable amounts of washwater on grass or via a municiple sewage system.
Here's what it says under "Chronic Health Hazards":
This is not to say (a) you'd want to pour full-strength stuff on your lawn or down the drain for disposal or (b) you'd want to get in your Brita pitcher of water in the fridge or (c) you'd want to pour gallons and gallons of washwater down the drain at once (etc., etc.)
I'll have to ask Nick specifically what happens to the propanols and the ethylene glycol when the solution is poured on the ground. When I posted before, he was giving me way more info than I could assimilate,being the engineer that he is LOL!, so I got him to "cut to the chase" before he finished explaining how those components get changed.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
