I just purchased a used Jet JWL-1642 EVS with some extras that made it seem worth $1450. He said it was about 1 year old, but was really 18-20 months. Turned it on and let it run, no nose from the bearings or motor and the head spur and tail live center lined up nicely. The old guy said nothing wrong with it and he seemed real honest. I Get it home and set up, can’t get the thing to turn without it wobbling just the slightest. Tried everything, face plate, Talon chuck, Nova scroll chuck that came with it, even bought 2 new 2″ & 3.5″ face plates, same thing. No mater what speed I use it wobbles enough so when I’m trying to turn a box or thin wall bowl I get paper thin on one side and 3/16th on the other. I had a Jet 1236 that I used for about 1 1/2 years and it was time to upgrade. Never had a problem with that machine ( maybe shouldn’t have sold that baby), so I have talked to the tech guys at Jet and said I may just need to get use to a new machine. I think that is not the problem. When I put my chisel to the wood after it should be plenty round, I still feel thump thump at slow speeds and it just about rattles the chisel out of my hand at higher speeds. If I can’t hear the bearings, does that mean that I may have a bent shaft? Or does that mean I probably got the shaft!!!! In any case what would be the first thing to do and so on. Thanks, Bill
Something is not right. Even with a bent shaft or lots of misalignment, you can still turn a piece so that it's round. The only way to get out-of-roundness is if the alignment changes during the turning process. So, I would have to think that not only is something out of alignment, but it's loose, too. (And it could be that the looseness is what's causing the misalignment.)
So Steve, you think perhaps it is I that could be out of alignment. HA Ha. So what else could be the problem? I am racking the brain, the only thing I come up with is bearings or bent shaft. Any body Help.
Steve, I have tightened every nut & bolt so to speak. I've been working with the Jet people, there just doesn't seem to be a logical answer. I just can't except that I have used a lathe for the last 2 years and now I don't know how to make this one work.(It's been a week now). It catches at slow speed after I turn my wood to what should be round and it still will thump, thump and at higher speed it gets violant. I am hoping it's not a shaft or bearings. It is what it is. What is the best why to find out what is what?
"It catches at slow speed after I turn my wood to what should be round..."
What does that mean? Is it round or not? (It should be easy to measure.) If it really is round, but now it's only catching at one point (easy enough to verify when turning the lathe by hand), the only possibility is that the wood has shifted since being turned round. A bent or misaligned shaft, or any sort of problem with the pulleys, cannot explain this. For the wood to have shifted, there has to be looseness somewhere in either the headstock or the tailstock.
Edited 6/16/2008 12:34 pm ET by saschafer
Good point Steve , maybe the centers when spread out are not the same anymore , but did he say even with face plate he gets the same ?
dusty
Yes, I,v been around lathes enough to know to check all the obvious. The same thong happens with face plates, spur centers & chucks. I wanted to blame a small blemish scared out on the inside of the forward shaft, but that wouldn't explain the chuck & plate.
If I read you correctly it seems that the lathe is vibrating, rather than having a bent shaft/spindle.
It is easy to check for spindle run out but this is rare.
So I suspect that something is out of balance-the usual culprit is a pulley, which could be bent, loose on the shaft, not true on the shaft or especially in the case of heavy cast iron pulleys it is not balanced due to internal casting voids.
Another cause of vibration is the state of the drive belt and or the tension of this thing. If the belt is tatty fit a new one and try different tensions.
Then there is the motor and motor mountings. Check the motor when it runs-is it stable and smooth running?
Then there is the stand on which the lathe is mounted - are the feet evenly on the floor? It may be useful to fit rubber foot pads to absorb vibration, and even add weights to increase the overall weight.
The "tech guys" at Jet don't sound much use if that is all they can say.
You sound like you have some knowledge in this field. I have tried adjusting the belt tension as well as putting extra weight on , that didn't work. It doesn't make sense why it would shake out of line at most any speed. Should I take it to a Jet pro or any other suggestion? Thanks, Bill
It may sound obvious but have you looked at the back register on the shaft.Is it clean no burrs etc
I suggest running the thing without any attachments on, all the little access doors open and take the machine through it's operating ranges. While doing this you may be able to observe and find the trouble through process of elimination. Please be careful though.
You may have done this already, but I didn't see it wrote in the posts.
Good luck,
Chris.
Make sure the tail stock is firmly locked in place. It is the only part that can move and make things go thump.....
While you're at it, CAREFULLY check the internal Morse tapers in both the headstock and tailstock for a ding, burr or even some paint. If the centers are not seated properly, they too will give you the 'out-of-round' feeling
SawdustSteve
Thanks, I did find a bit of tare out inside the headstock right at the leading edge and I put emery cloth to it. I hope the isn't the problem as I sure the is an expensive fix. The tail stock would not effect the trueness of the headstock because I'm not using it when turning lids or the like for small boxes. I thought I would give it one more shot at adjusting the feet on the stand before I strangle an old man. Poetic don't you think? Hardy har har. fThanks For your input, Fishwood.
fish,
If all the tapers are clean , is it possible your step pulley if yours has them , could be bent or have a chip or piece missing or an Allen nut / set screw part way out that holds the pulley to the shaft ?
are any and all pulleys lined up correctly ?
dusty
I think all the pulleys are lined up from looking at them, but I'm not really sure how you tell other than watching them. I have put a run out gauge on the shaft and I get .005 witch seems tolerable. This is got me going. I may have to take it to somebody who is in the know and spend bucks I shouldn't have to. Thanks, Fishwood
My first lathe had the same problem from the sound of it. Mine started off barely noticeable and soon became unbearable. On my setup it was bearings. If I put a large piece on a face plate and tugged around at it, I couldn't feel anything. Get it spinning and it was a whole different story. If it is your bearings, they should be relatively easy to replace. Good luck.
