I am in the process of constructing four mahogany and curly maple interior columns. The majority of the columns will be mahogany and the curly maple will be the panel portion of a frame and panel bottom.
I am going to finish the mahogany with shellac or varnish. I would like to keep the contrast in colors between the mahogany and maple. I was thinking of maybe using blond shellac on the maple and a darker shellac on the mahogany. Anybody have advice on how to pop the curl on the curly maple without altering the color too much?
Do a sample piece, and you'll know for sure.....
But I'd bet that the shellac will do the popping just fine.
I won't be laughing at the lies when I'm gone,
And I can't question how or when or why when I'm gone;
I can't live proud enough to die when I'm gone,
So I guess I'll have to do it while I'm here. (Phil Ochs)
you might try a sample of a water dye stain on the maple only - maybe an amber or yellow color top coated by clear shellac . The mahogany can be brushed with shellac tinted with a red dye that dissolves in alcohol - try sample first -
SA
Wolfman ,
Before doing too much , I'd suggest trying a clear natural finish not Amber or Orange or any other color . Personally I use pre cat lacquer .
The woods are so beautiful in their true colors why try and enhance more
regards dusty ,boxmaker
Thanks everyone for your replies. I will do some samples of different finishes and dyes. Since these columns will be finished in the house I figured shellac would give me the quick dry time and little vapors for my daughter, wife and dog to inhale. Any water based finishes worth considering?
I never had luck with water based products -
Shellac odor isn't too bad - crack a window - use a fan, and don't try to coat everything at one time - do sections -
I use shellac all the time indoors - each person has their own level of tolerance.
Give the Mrs. the credit card and tell her you need several hours to work - I'm sure she'll agree to go shopping while you finish the woodwork.
Good luck
SA
Thank you for the reply. I think shellac will do just fine indoors. I'm thinking touch up will be easy in the future also.You obviously have met my wife, she and my daughter live to shop. I'm doomed.
Ric Hearne from Hearne Hardwoods showed me how to pop the curl with out coloring the wood. He said to use dark aniline dry and stain it black. After it dries, sand the dye off. The end grain of the curl in curly maple absorbs more of the dye and when you apply finish it really helps to pop the figure. I figure if you treat your panels this way before you glue up the column sides would be the easiest way to do this so you don't have to mask off mahagany.
My thought exactly. Although I may go dark brown or mahogany with the initial dye. Black you say? I'm curious as to why he would recommend black, don't you see traces of it after finishing?
I've never done it with black dye but I have done it with carmel. I've never had the need for light natural maple, most of what I do is reproduction work. I usually apply dye stain in two or three coats sanding heavily after the first coat and minamally after the second to pop the figure. This eliminates the need for prewetting the surface.
