I am curious what strategies you use for DC on you RAS. I can’t figure anything out. Please post Pictures if you have them.
Thank you
Thank you
I don't use my RAS for ripping any more - I expect dust collection would be impossible.
For cross cutting, I simply built a hood of cardboard and scraps of plywood behind the saw, using lots of duct tape. Starts with a diagonal piece in front of the column, attached to a scrap of wood jury rigged into the saw frame behind the table. The 4 inch hose connects at the side, near the bottom. Ugly as sin (no picture), but it works when the DC is on. If I have a quick small cut and don't turn the DC on, it is really good at blowing the dust back into the room.
________________________
Charlie Plesums Austin, Texas
http://www.plesums.com/wood
I can explain the setup, but I'm illiterate with attachments/photos.
We use an RAS with a sheet metal box, attached to a hose, mounted at the rear against a wall. This is on the table and works well.
The local lumberyards have a box setup behind the saw that is connected to a serious DC system. It seems to work very well for cross cut work and if the customer wants something ripped, it's done in the millwork shop on a table saw or panel saw.
When I used to have a RAS, I had some success (both ripping and cross cutting) by connecting my shop vac hose to the rubber port on the blade guard. It didn't get it all, but it helped.
Check out this forum. Someone here led me to it and it is full of great tips and discussion on RAS. I know there are discussions on dust collection. http://forums.delphiforums.com/woodbutcher/start
Beyond that I know that Rockler and Wood Craft sell a Sliding mitersaw/ RAS dust hood. You still have to figure out how to attatch it. Also you can go to Home Depot and look in the Heating/ AC isle at the air duct fittings and adapters. There is a fitting that goes from 3"x6" rectangle to 6" round. You then use an adapter to reduce it to 4" all of this is in that isle. If you dont find that, and don'twant to look around for it, get a "register box" of the same size. The rectangle to round fitting is easily trimmed or modified to optimise collection. If you can mount it to the gaurd assembly that is best, otherwise mount it at the back of the table as close to the fence as possible.
Hope this gives you some ideas,
