I have a maple sofa table that has been sealed with wax free shellac and 3 coats of minwax(oil based) rub on poly.
I would like to darken the table as it looks too plain and lacks depth eventhough the grain looks terrific.
Any suggestions?
Thjanks, Searle.
You have basically two choices. First isquick and dirty. The second is the way it should be done if you want the best looking result.
The quick and dirty is to use a tinted oil based varnish like Minwax Polyshades. However, this product if very problematic as it tends to color unevenly. Any variation in the film thickness will result is varying intensity of color tone. If you go this route first scuff sand the surfaces with 320 paper to create better adhesion for the Polyshades.
The way it should be done is to use a chemical stripper containing methylene chloride and remove all the existing finish. No you have a clean pallette to do with whatever you want. Be aware thogh, maple is a wood that tends to color unevenly when a stain is applied. The most controllable process is to first apply a 1a# cut of shellac. Then use a gel stain followed by anothert coat of shellac. The use the clear coat of your choice. If you plan to use a poly varnish clear coat, be sure to use a dewaxed shellac. Your project will look nicer if you use a non-poly varnish.
A reply
Thank you for your time. Is there any way I can apply a gel stain over the poly?
Tnks again, Searle.
Yes, you can use a gel stain but you will be subject to the same issues as you would using a tinted poly product. Unless it is put on very evenly, it will appear uneven once it dries. Gel stain over an existing clear finish is what is called toning. It's a technique primarily used to vary tone shading to create a particular "look". You can try. Scuff sand the surface with 220 paper sanding in the direction of the grain. Vacuum and begin wiping on the stain. Then, with a clean cloth begin gently wiping with long strokes to even out the stain. Let it dry and apply your clear coat.
Let me strongly suggest you make up a sample board finish exactly the way to finish this initially. Let it dry and then go through the gel stain process. This will give you a chance to learn how to do it and see how you like the results.
finishing maple
Thanks, I will try the gel over the poly on a test board and see how I like it. Thanks for your time. Searle.
