—My brain is getting tweaked installing crown molding on various bullnose corners. I am cutting the crown “flat-style”. And I am using a small 3rd piece(short to short measurement about 3/4 inch) on,say, a “typical” bullnosed outside corner. I think I have it down if the corner is right at exactly 90 degrees, but not yet for ,say, 89 or 91,etc.
Also, the next room has some 135 degrees (due to a fireplace) and I want to maintain the three-piece-corner look. The spring angle of my crown is 30 degrees. I have a Bosch angle finder, but it doesn’t want to compute this situation… Maybe I should just simplify by switching to the “upside-down-with-fence” crown technique???
THANKS!
If at all possible, that is what I do. The KISS principle is often the best.
Frequently enough it requires that I mount a higher auxillary fence to accomodate the crown, but you only have to make it once and then use it forever if you take care of it.
This, of course, requires that the saw is of a size that will handle your crown in this manner.
Can't recall at the moment with certainty, but this page may contain what you're looking for.......
http://www.dewalt.com/us/articles/article.asp?Site=woodworking&ID=2
Steve -
I have always made a miter box for each crown molding job. I make it so that the inside is wide enough to hold the molding upright at the proper angle with the bottom of the molding resting against the back bottom of the box and the top resting against the top front of the box. That helps my simple mind better understand the geometry.
I have a 6" deep hand miter saw which helps for the wide stuff.
For weird outside angles I lay a 1x4 up to the ceiling against one wall and another across it from the other wall. I then scribe two lines on the one underneath and later draw the bisecting angled line. That then is the angle needing to be cut.
I always cope the inside corners.
I just finished doing this house about a year ago. Did every room except for the bathrooms and kitchen. Fun job!
http://www.josephfusco.org/Articles/Crown_Moulding/crownscript.html
The above link is an on-line calculator for crown molding angles. Key in what you know, and it figures out the rest.
