My radial arm saw doesn’t get much use now. By attaching a chuck to the arbor and mounting linear bearings or some other sliding table on the sawtable, the saw could be made to function like a slot mortiser. Have any of you done this? If so, would you mind sharing your design and recommending a source for the appropriate chuck and other hardware. My saw has a 5/8″ arbor on one end and a smaller arbor on the opposite end.
Start Your Free Trial
http://www.mcmaster.com has chucks as well as http://www.mscdirect.com. I think you would be better off selling the radial arm and putting the money toward a slot mortiser. I think you will find it to cost more to convert your saw than getting the Grizzly G0540 which a few folks have been using quite nicely as a slot mortiser.
http://www.grizzly.com/products/item.cfm?itemnumber=G0540&gid=044E13FB-685A-498F-89E3-6CC57961B4C1&site=grizzly
Once you experience the slot mortiser you will wonder why you waited so long!!!
Edited 7/7/2004 5:33 pm ET by rick3ddd
The Grizzly link you included went to their home page.
Do you have a more direct link to the particular slot mortiser you are recommending?
Thanks.
That's weird. Link was copied from the mortiser page and when I tried it after you mentioned going to the home page it wouldn't go to the mortiser.
http://www.grizzly.com/products/item.cfm?itemnumber=G0540&gid=6DD4D137-CBE1-4F2D-A9CE-5A9B1D437FF1&site=grizzly
If it does it again type G0540 in the Grizzly search window.
Thanks. The new link went straight to the machine.
What are the bit choices for such a machine?
For mortising HSS 2 flute endmills for machining aluminum work great. You need to put a bit of 625 loctite on the shaft as the G0540 is primarily designed as a horizontal drill but it seems to be getting positive reports so far. If I didn't have a slot mortiser already I'd certainly be willing to spend that pittance of $330 delivered. Can't even buy a motor for that price. No way anyone could modify a radial arm saw to come close to the same performance. Sears used to sell all kinds of junk to add on a RAS.
Gotta agree with Rick. I have a slot mortiser on my MiniMax combo and it is neat, very neat.
This the first time I have seen the Grizzly unit. I would take a look if I were you. Looks nice. The price is right and the capacity is good for a machine in this class.
_________________________________
Michael in San Jose
"In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted." Bertrand Russell
Friend,
the 'tool' end of your radial arm saw may very well fit an inexpenssive (less than $20.00) threaded Jacobs chuck sold at Sears in a blister.
Then you'd make a simple, clampable elevated table with a stop and lever-clamps to hold the work-piece.
The table would be just high enough for motor clearance and you'd use not drill-bits but end-mills.
You'd have to figure a means to stop the cut-depth, probably at the arm. Some RAS have that feature already, but there'd be several ways to do it.
You can also put a router on it, but really, you could tune the RAS and get some good use for it.
One important use is, unquestionable, cutting dadoes with a dado blade.
To avoid moving the arm, you can use a plywood triangle cut exactly at 45 degrees as a guide, that being the most common cut. You can also improve the safety with lever-release clamps, and can even make a roating fence for varied angles, as the one here. That way the RAS is always cutting in a straight forward line and stays true.
-mbl-
Making jigs like this to adapt RAS is a quick way to save time I have found also mbl. Keeping it set with a standard known measure of depth, cut size, and to molded cuts you can soar through a lot of material accurately in a short time what ever you need to do. Now you got it!
In a kitchen cabinet company there are certain things we stock next to the "specialty" equipment areas. Like for instance we store oak plywood rips at 11 1/4" and 23 1/4", oak is our standard material, right above a overhead router that is assembled only to do 90 degree 1/4"D x 3/4"T cuts. You can knock out the carcasses quick this way. Same with the faceframes that I make, the ripped stock is right over the accurately set miter saw. You have your cut list, just knock them out and have a cup of coffee to spare. - Curt
I recall several clever designs for radial-arm saw jigs and fixtures being published in "Using your radial arm saw" type publications, both by Delta and Sears, and I'm sure there are many more. A slot mortising table was included in both of those mentioned. Some remarkably clever!
My old Sears radial arm saw carries a ourboard end mounted bracket supporting a plunge router with foot pedal/linkage for use as an overarm pin router. Saw motor hasn't been powered for fifteen years!
Good luck
I have the top handle Bosch and really like the feel of it.
Pete-- Deep in Cajun Country
One Nation UNDER GOD
<img src="http://216.77.188.54/coDataImages/p/Groups/90/90613/folders/85890/874182movingplane1.gif" width="119" height="41">
