O.K. folks checked the archives and found a few discussions on air compressors, but being the lazy ba*tard that I am I couldn’t find every thing I needed to know–so here goes:
My planned uses for an air compressor are:
- Woodwork in my shop
- Trim work in my home
- Removing stucco with an air hammer from my 1880 Italianate home that someone bastardized in the 1970’s. (Why would anyone do that?)
- Nailing siding and restoring trim work on home that someone destroyed in the 1970’s (why would anyone do that?)
- Other restoration uses…because someone bastardized the home in the 1970’s
I’d appreciate any and all suggestions. My specific questions are these:
- Oil free or oil lube?
- What size? (no painting)
- Name brands?
- Any feelings about the big Coleman compressor sold at Costco?
- Any other things that I’m not considering?
Thanks for the help…
It's unclear from your post whether portability is a requirement. Other than that, here are a few suggestions.
One last word of advice: don't cheap out. You'll regret getting one that can't keep up with what you're doing, or is totally annoying when it runs (oil-free). If it's a one-time job (chipping stucco), maybe renting is a better option, and buying a smaller portable unit.
Be seeing you...
I'll start by agreeing with TDKPE. I just looked at the Coleman compressors, but you didn't say which model. Big would probably be the 60 gallon upright. I think they're actually made by Cambell Housfield. As was mentioned, start with the CFM requirements for the largest item you'll be using, and don't underbuy. Also, take a look at the new PC compressors. In general, they have higher ratings than most others in that price range. BTW, an air hammer might range from maybe 5-20 CFM, depending on the size, so you need numbers here. Finally, what about portability?
Gerry
I'm waiting for a campbel hausefeld, It's one you have to order. Its as mobile as a 10.3 @ 90 psi gonna get, found it on the net. It's 220v, 26 gallons, oil bath, and, 6hp, and should be what I need, $460 after tax and shipping (no shipping, but CA taxed).
By the way the difference between oil free and oil is if your going to use an oil free in dusty or dirty conditions it will effect it's life span more than a oil bath.
john g
Edited 8/2/2002 1:25:29 AM ET by john
Thomas, Emglo or Rol Aire brands, Oil lubbed. Buy those if you want a long lasting, fairly quiet compressor built to handle. Only if you decide to use air tools for mechanic work would you need a stationary compressor.
I concur with Bill with the three compressors mentioned; of those three I prefer Emglo. Emglo (the blue ones) I think has been bought out by DeWalt and are now yellow color (do not own one of these to comment on). I purchased mine from amazon .com a few months ago to relace a loud oiless; the neighbors at the jobsite rejoiced at how quiet it was in comparison.
Hopped over from home building and saw your post. I've got a cambell housfield 5 hp. Converted to 220v by following the directions on the inside cover of the motor. As portable as I need and runs all the tools including a small sand blaster for small jobs. Just have to wait for recovery once in a while. I can wrestle it into a pickup myself if need be.
