Hi all.
I’m planning on building a treadle lathe. I’ve done a little spindle turning, am fascinated with the idea of bowl turning, but I won’t be able to spend the dough on the lathe I want for quite a while.
So what I need to know is what size of headstock spindle to buy or have made for it. Is there a common size (1″ x 8tpi) or are there accessories for every size? I need all the help I can get. I’m leaning toward a 1″ spindle, 8tpi with a #2 Morse taper in the end. The outboard end will be the same except left-hand threaded.
What size is the spindle on your lathe and is it easy to find the chucks you need?
Edited 5/24/2003 11:16:57 AM ET by jase
Edited 5/24/2003 11:18:09 AM ET by jase
Are you building a Spring Pole Lathe or Treadle lathe?
The treadle will turn a flywheel.Jase--Is there a better way?
I don't know if this will help you much might get some ideas- Treadle Lathe
http://www.his.com/~tom/sca/lathes.html
Just a thought have you ever thought about a Pole Lathe? I think I would like to try one - I have seen them made several ways not just with the big pole outside but that would be cool -I like working outdoors.
might check it out
http://www.rushworth.com/green/index.htm
you can find lot more on the web
http://www.bodgers.org.uk/explorer/front.html
Edited 5/26/2003 1:46:07 PM ET by I Like Beans
Hi, I have a fifty+ year old Atlas wood turning lathe. I don't think it was used much as it is in like new shape. I got it at an auction along with a bunch of attachments still in the Atlas boxes with the paper wrapping on them. Having said all this my one big dissappointment is that it has a 1 x 10 spindle on it. Not a real common size. However, Grizzly sells adaptors for a 1 x 10 spindle and so does Oneway. As a matter of fact I've bought a lot of stuff from Oneway and they are super to deal with. One gentleman with whom I was talking said that they (Oneway) had about 100 different adaptors for their products. Getting back to your original question, in my humble opinion, 1 x 8 seems to me to be the most common size for a lathe spindle. Have you considered joining the American Association of Woodturners? An afterthought, there is another woodturning company called Packard that is real nice to deal with too. Bob
One good turn deserves another.
