I recently saw an article in “American Woodworker” (Feb) that illustrated various picture frame profiles achieved using combinations of ordinary router bits. Has anyone seen a similar article/book/guide that shows possible moulding options that can be routed by using a combination of bits?
I’ll likely do some experimenting but after seeing the article I can see the benefit of an illustrated guide (not to mention the $ savings on owning so many specialty profile bits.
mike
As to seeing a book on mixing and matching profiles of bits, No I have not. But I do it often when doing picture frames and it can be time consuming to get what you desire. But I have taken full scale catalog photos and cut them out and piece them together to see what I can get rather than experiment on lumber. The possibilities are endless and limited only to your imagination.
Bruce S.
I haven't seen an organized guide, either, but the potential combinations are almost infinite.
I think there is a certain Zen to the whole thing. Once you "become one" with your router bits, you'll start seeing their faces in the clouds. ;-)
at last years wood working show in STL, Freud had a bit set for Picture frames and a video that came with it. I cant remember it specifically but I was out of money and did not pursue it. It was a nice set and the combinations make some spectacular frames. I know there's a dude from freud that frequents this forum, maybe he will see and know what I was speaking of. Sorry, but I can't remember his name. Good luck.
I have seen articles in Woodsmith on this: check their archives. Probably every woodworking magazine has done the same over the years.
There is a chapter on making your own profiles in the book "Making Picture Frames in Wood" by Manly Banister, Sterling Publishing. My copy is dated 1982 although I just bought it about 5 years ago. It is not well illustrated but should give you some ideas.
You can do a lot with basic router bits - straight, cove, round-over, etc. Eagle-America has some interesting profiles in a size proportionate to normal-sized frames.
I must admit that for me, it is hard enough to get one consistent routed edge, so I have come to avoid complicated profiles. I find that plain and simple works best for me to showcase the beauty of the wood.
I guess I should have mentioned that I made the props for this link. http://eagleamerica.com/picture-frame-and-mirror-bits/p/165-0105/r
The lumbers were curly maple, Honduras mahogany, walnut and cherry. Upon completion of the corners and carrying them back to work. I happened to stack them together and decided how interesting it would be to mix up the contrasting lumber strips and different profiles. Glue them together for a wider and more complex profiles.
It was a stroke of luck and weird imagination.
Bruce S.
