I have recently purchased some white oak lumber from a furniture factory which closed after 40 years. most of the lumber is D or better, but some must have been on top of the piles. It is in need of cleaning before I plane it. If I power wash it will it soak up so much water that it will warp or need to be dried. it is indoors now in by barn but I have just put on fresh planer blades. What is the best way to clean it up? Thank you for the reply. ANDY
Mr. (Lumber) Clean
I'd give it a good brushing with a natural bristle brush (or similar rotary brush on a powered flex shaft) and then vacuum the heck out of it. White Oak is closed cell, so you shouldn't have grit hiding in the pores like you would with Red Oak. But I'd still do a close visual inspection under magnification, though. Also, you might use a scraper on the surface prior to planing, as an added precaution.
Dirty Wood
Can you brush it off - than put back the old planer blades for the first pass -
SA
hello, the cleaning in fact exists out of two steps: The first step is applying a product that contains sodium percarbonate. This chemical component attacks the dirt, mold and dead grayed-out grains. Second you need to apply a wood cleaner and the deck cleaner is almost always acid and this balances the pH. Cleaning your wood means actually opening up the pores of the wood and provide a fix for a sealer and a stains.
