Howdy,
I just got a back issue of FWW ( sorry can’t seem to find it right now so not sure of the issue). It’s a recent issue dealing with chisels. It’s where all the tests are run with a stylus across the tip then used for something like 30 blows and retested. In it most all “western” chisels-Marple Sorby etc come out way down the list while japanese come out on top by a long shot. The scale being 1-16, 16 being worst 1 best. Most Japanese coming out 1-3 and the marple etc getting like 15’s!! No indication of real bad ones maybe a bad chisels would rate 200! so in reality they are not that different. I’m not so sure I buy into all this but have made some observations of my own over the years. The blue handle Marple certainly don’t hold all tht great an edge. Sorby’s do quite well. Japanese ones I’ve tried ( sorry can’t recall brand were very nice but brittle and a little harder to sharpen and once you get past the first 5mm they will harder to deal with. I like the Japanese and am considering a purchase of some of the better brands that high rankings. I’m betting that when this article originally ran there was much debate. Anyone feel like rehashing it? Or filling me in? What brand/kind are you all using?
Warren Allen
This reminds me of a post I read on another forum about Japanese forging technique...
Apparently a number of Japanese chisels are made with methods similar to the katana swords carried by the samurai in feudal Japan: a blank of pig iron was folded and hammered 200 times to create over 3,000 laminate layers of very high carbon steel. This steel sharpened to and held an edge so keen that the sword was tested by seeing how many convicts it could cut in half in a single stroke. The downside was its brittleness; a man of average strength could stick the sword in the ground and break it in half. I've always been wary of japanese chisels for this reason, although I am looking into some hand forged laminated plane blades. I use Marples chisels in the shop, but mine aren't the blue ones, mine have boxwood handles. They've always served me well and require only occasional honing.
Warren,
I did not see your study, I wish I could. I read one recently that had Marples on top and the others you mentioned down the list. It appears the criteria that is used makes all the difference. In the study I read the key variable was retaining sharpness...after how many chops, etc.
I'm trying to select chisels right now. High carbon steel sharpens beautifully but durability is limited. With different alloys, sharpening becomes a little harder..but durability is improved. I'm kinda thinking start choping with the durable chisel and moving to the high carbon for the finish and paring. Other than that, its all about personal feel and personal taste. I like the feel of the japanese ..not too heavy..and being a little shorter seem easier to chop with when sitting down...but that is me. What I don't know is if i put a 15-20 degree bevel on them for paring...would the brittleness become an issue
I love the look of the Swedish, Sorby and Two Cherrie chisels. These are alloys and should be less brittle with a better sharpness retention. However, I have not tried any and don't know about the feel.
Isn't LN comming out with chisels? It will be interesting to see how they balance the issues..
For right now, I'm gonna buy onesie, twosie and have fun choosing...maybe carving tools have some of the answers I'm seeking.
Edited 12/7/2002 6:06:57 AM ET by BG
I believe FWW on Small Shops has an article on chisel tests followed by a brief rebuttal. In the rebuttal, the author points out that the differences used in the test are actually quite insignificant and that with the exception of the cheapest chisels, they all perform quite well in actual use. He recommends going with chisels that feel comfortable in your hand.
He also points out that only the end of Japanese chisels have high grade steel (only on the cutting end), this being forged to a lesser grade on the remainder of the tool. Goes back to the time when steel was difficult and expensive to make.
Hi,
I use the standard blue-handled Marples brand.
As a fairly-new (3 years) woodworker, it's easy to get tempted by "better tools = better craftsmanship"...and the equally dangerous 'high price = better quality".
I've begun taking a series of hand-tool classes with an English-trained Master Jointmaker..who has been building furniture for 40 years..by hand..and can justify any tool that he wants. He uses, and recommends, the Marples as of good user-quality, that function well. He sharpens his chisel EVERY time he uses it..just keeps a diamond stone on the bench and gives it a few laps..and then a few strops...
For a "user" the Marples are fine. If you want an heirloom to will to your kids, get something pretty and expensive. But don't confuse the two purposes.
