I have been practicing my chisel skills…without much noticeable improvement. It appears I’m getting a kinda tear out cutting across the grain..as in dovetails. When I start choping the first 1/8″ is good, but then is appears to stop cutting and takes out chunks of wood. The last 1/8″ is good also. So instead of a nice clean end gain look, mine has these chunks mising on the inside. I’ve tried hitting softer, harder, …what am i doing wrong?
First thing to check is the cutting edge. You need a good sharp chisel before you start. A sharp edge will make the learning curve smaller and you won't get frustrated as much. Do a search to see if you can find some tips on sharpening tools.
Scott
Scott C. Frankland
Newfoundland Wood Worker
It might be dull tools, but you aren't just trying to chop straight down, are you? You have to chop down, then remove the chip, then chop down some more, then remove another chip, etc. If you just stick the chisel in the wood and start hannering on it, it acts more like a log splitter than a cutting tool.
Tom
Maybe I'm not removing the chips frequently enough? ..or getting chips removed close enough to my cut line?
what wood? i notice that i get some chunck popping out on cherry, but mahogany remains perfect. you might also try a SLIGHT undercut. That is, not perfectly 90 degrees, just a tad in so that you end up with a shallow v. the end grain won't provide much if any glue holding power anyway.
S,
I had the problem in mahognay first..thought it might be a bad piece. Same, same in maple and last night in several pieces of pine I cut up to practice on. What about width of blade, could that make a difference? I normally use a 12mm (1/2 " about) to start out with. The other thing I wonder, am I letting the edge bounce...
BG,
I like the advice to try making paring cuts rather than driving the chisel with a mallet. You will quickly find out if your tools are really sharp. One of the pitfalls of SS is that you can very easily dub the edge without knowing it; it will still shave hair but won't cut end grain.
Alan
I just tried some horizontal paring...pretty easy in pine...not so easy in maple.
Are you cutting all the way through the waste on one side, or flipping the board over when you're half way through? Try making a paring cut on end grain and seeing how that turns out.
Tom
Scott,
There sharp chisels I'm using, believe me, that is the first thing I took care of..up to 2000 grit. Even my wife noticed how much hair was missing on the back of my hand...lol.
I've tried to use a block of wood to ensure i was staying at 90 degrees, and taken back cuts to open up the space for the edge of the blade to do its work of cutting. Nothing seems to work...chunks get removed instead..leving holes on the inside.
